having trouble with plugs
Old Aug 18, 2003 | 06:23 PM
jkoon's Avatar
Question having trouble with plugs
Is anyone else here having trouble with sparkplugs? i keep melting the ends off of them. im not sure what the problem or the fix is. so if anyone has any ideas id really appreciate it.
Old Aug 18, 2003 | 06:29 PM
Dan_03Lightning's Avatar
What type of plug are you using?
SpankDog's Avatar
Banned
your running lean and your lucky that you've only friend the spark plugs so far.......lets hope.
edit.......or you might have the wrong plugs...
Old Aug 18, 2003 | 07:24 PM
BDAZSVT's Avatar
I had trouble with a plug this weekend. It decided to leave the head. *Warranty*
Don's Bolt's Avatar
My thoughts exactlly
with your mods i would recomend NGK TR6's
Old Aug 18, 2003 | 07:27 PM
LIGHTNINROD's Avatar
Or to be even safer, NGK BR7EFs which is what I've been running for 30k with my 5 lb pulley.
Dan
Old Aug 18, 2003 | 11:45 PM
SpeedJunkie's Avatar
You have a bad program. Your stock plugs are good for the mods you are running.
Are you runing stock plugs?? Your "mod list" suggests so.
Old Aug 19, 2003 | 12:30 AM
alphadoggy's Avatar
Get those platinum plugs out of there STAT and install some TR-6s. (I've got a set I'll sell you cheap).
Old Aug 19, 2003 | 02:15 PM
jkoon's Avatar
ive been running tr6 for the past year and they just dont last in my truck.
Old Aug 19, 2003 | 02:17 PM
tommylightning's Avatar
Sounds like a reburn is needed.
Old Aug 20, 2003 | 07:17 AM
loosebolt's Avatar
One of the friends fried 7 of the 8 spark plugs REAL BAD. They were the correct heat range and everything.
We had his a/f tested a few weeks ago and it's insanely LEAN!
If you have the right plugs, or even close to right as I don't think 1 heat range hotter would cause this to happen this often, I would suggest a chip reburn.
