Shock set up???
Old Aug 18, 2003 | 11:00 AM
Dan_03Lightning's Avatar
Question Shock set up???
I spoke to a friend that races regularly. He has a 8.9 second chevy pick up (I believe it is a '58).
He told me before I get serious about heading to the track I needed to change my front shock set up to improve weight transfer to the rear.
Suggested a 60/40 or a 70/30 front shock, but said talk to guys who are pulling good times.
What shock set up is recommend for our L's? And is there a particular brand that you suggest?
Thanks!
Dan
Old Aug 18, 2003 | 12:47 PM
Konig's Avatar
I think most of the serious track guys are running QA1s ..they are adjustable for street/strip applications
Old Aug 18, 2003 | 12:58 PM
SpankDog's Avatar
Banned
QA1's
http://www.nloc.net/forum/showthread...threadid=14727
$675
Old Aug 18, 2003 | 01:33 PM
That is some serious cash.
Does anyone know the settings they should be adjusted to for the front?
Can I get away with only changing the fronts?
Spankdog, everytime I see that "drunk photo" I crack up,
Thanks guys!
Old Aug 18, 2003 | 01:48 PM
SVT_KY's Avatar
Drop the sway bar too ...
Old Aug 19, 2003 | 12:47 AM
promodlightning's Avatar
Dan, your optimum setup would be: remove front sway bar and install a set of QA1 shocks set at 90/10 and the rears Id leave at 50/50....this will allow great weight transfer....but these shocks are pricey.....
Old Aug 19, 2003 | 02:14 AM
L8 APEX's Avatar
I believe the ratio on the QA1's remains constant just he overall stiffness is adjustable. ie always a 60/40 just softer or stiffer. Stan would be the one to check with.
Old Aug 19, 2003 | 07:40 PM
Thanks guys, that really helps!
Old Aug 19, 2003 | 09:32 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
promod, Dan
The shocks are a bit pricey however they can be rebuilt and offer flexibility whether you prefer pummelling apexes, ripping up the 1320, daily driver, or all.
Bob
Old Aug 19, 2003 | 10:19 PM
Speedin Bob,
I would have to do a heck of a lot more than just shocks to actually prepare my L for road racing, wouldn't I??? If I went down that road one day.
Dan
Old Aug 19, 2003 | 11:26 PM
Dan,
The funds associated with prepping the truck with a respectabe road course setup is less than the outlay for a reliable 11 second quartermiler.
It all depends on your specific goal(s) for the vehicle and at what point either application sacrifices acceptable driveability vs. safety requirements (ie: roll cage)
Bob
Old Aug 20, 2003 | 01:15 AM
Yeh, my next step is to find a good rollcage installer/fabricator.....
Old Aug 20, 2003 | 07:16 AM
Thanks Bob, Pete the way I am going I may not be far behind you.
Dan
