Extra Low End torque Killed Top End?
Old Aug 17, 2003 | 02:35 AM
Jerzey's Avatar
Question Extra Low End torque Killed Top End?
Anyone know whats killing my ETs? Here's the deal, my 99 Crown Vic with an Eaton blower out of the box ran 14.3 @ 95mph... I added a metal intake tube to replace the stock rubber one and a Lightning heat exchanger courtesy of Gator (thanks again Gator!!!) and my ET's went down... the car would only do 14.4 @ 94 on drag radials and 14.6 @ 95 on street tires.
Now posting on the Vic boards everyone says I'm crazy for complaining the car has too much low end torque... apparently its a good thing. But my top end is now shot, I spin out off the line and than I have to stare at the *** of a stock crown vic all the way to the finish line because there's no way I can catch up.
What would create such great low end torque: the metal intake tube or the heat exchanger.... just curious?
--Russ
PS. How do I fix this... and actualy run faster with my mods.... my whole rear bumper is black from rubber bits. I spun out more off the line than I actualy hooked up. It was embarrasing.
Old Aug 17, 2003 | 06:45 AM
Ak.Silver2K's Avatar
Weather
Was there more humidity (& heat) the day you ran after the mods? Can't see where these two mods would do anything but help all the way down. Perhaps you have a vacuum leak from installing your intake tube. The heat exchanger is gonna give you a denser air charge and the bigger increase in power, but like I said, it should help more than just off the line.
Good Luck,
Mark
Old Aug 17, 2003 | 08:38 AM
Rob_02Lightning's Avatar
Russ
Ya like Mark said,
neither Mod should have effected low end torque to a point
where it became a problem (or slowed you down) ???
And what are we talking about here, 1/10th
I'd guess more at this point that the heat exchanger helped to the point that the cooler running S/C now makes a little more power (which you want) and as a result, you now have a traction problem. You seem to agree that it won't hook all of a sudden ?
WHAT SIZE DRAG RADIALS ARE YOU USING?
WHAT TYPE OF STREET TIRES ?
AND MOST IMPORTANT, WHAT PRESSURE ?
That's where I'd be looking
I've cut 1.8 60ft times on the stock F-1's @ 25lbs of air pressure
and I cut 1.6 or 1.7 on 28x10 Hoosiers at @18lbs of air pressure.
(next time, I'm going to try a little less air)
At 18 they look like this
A matter of fact I drive on the parkway to the track on them
and then make my passes without touching the air pressure.
It looks to me like I can take plenty of air still out of them.
You know plenty of us are cutting great 60's and great ET's
without spinning problems. Schitt when I juice it on top of my regular Mods, my guess is I'm launching with mid 5's maybe closer to 600lbs of torque, and I don't spin the tires one bit cutting 1.6 60ft times
I say you got a traction problem, NOT A TORQUE problem
Old Aug 17, 2003 | 12:28 PM
Fast Gator's Avatar
Preach the gossip brother Rob
Torque = traction problems
Old Aug 17, 2003 | 01:36 PM
Jerzey's Avatar
it was hotter and definitely more humid at the track.
I played with the air in my street tires form 40psi to 30psi back to 40psi. At first it would spin like crazy at 40psi, I let the air out, made two 14s passes, than I'd spin again. I raised the pressure back up and it did OK at 40psi. The ricer I was talking to at the staging lanes was like, dude let it out all the way to 20psi... but I didn't want to pop my tire, they're too expensive to destroy.
here's my time slips from before the mods and after the mods:
my friend Charlie raced my car a few times and actualy got me some decent times the first time, but on the second one he spun all the way thru 3rd gear, loosing to a Marauder. like I said it was embarrasing.
--Russ
Old Aug 17, 2003 | 01:39 PM
Jerzey's Avatar
here's the slips from Englishtown a day before Island:
this was on drag radials with ZERO spin.
--Russ
