Installing my E-fan questions
Old Aug 14, 2003 | 03:41 PM
ShadowLightning's Avatar
I'm currently installing my waterpump and E-fan from LFP and had a few questions before going on with the install. I've pulled out the old fan and shroud already and the SC belt is off. I now need to remove the accessory belt...what is the best way to do this? Where do I pry to remove it? Also, the stock waterpump is the one that the stock fan was attached to correct? So the waterpump pulley is where in the engine (sorry, I'm new at this stuff) Any help would be appreciated, also if there is an online instructions with pictures, this would help. THanks
Old Aug 14, 2003 | 03:46 PM
SpankDog's Avatar
Banned
http://www.teamjdm.com/id78.htm
Old Aug 14, 2003 | 04:04 PM
Alright, that helped a lot, thanks Spankdog. But I'm stuck on step # 23. I have a 1/2 drive with 6" extension and trying to rotate the damn tensior but the thing doesn't fit right, it's too small (the end of the extension that is) Any suggestions? Otherwise, once I get past this the waterpump install and getting the fan in there should be a snap, besides the wiring.
Old Aug 14, 2003 | 04:07 PM
SpankDog's Avatar
Banned
so the 1/2 inch drive extension is too small to fit in this hole?
Old Aug 14, 2003 | 04:10 PM
exactly. It goes in, but I can't rotate the thing for *****. Any ideas? BTW my L is a 2001 if that changes anything
Old Aug 14, 2003 | 04:16 PM
Nevermind, I'm an idiot I got it.
