Are my rotors on wrong???
Old Aug 9, 2003 | 09:35 PM
J15BIG's Avatar
http://www.baer.com/Support/TechTips.aspx?TechTipID=2
Old Aug 9, 2003 | 09:38 PM
cpeapea's Avatar
looks like you got it backwards
Old Aug 9, 2003 | 09:43 PM
hdmlnium's Avatar
This is how I put mine on (ruslow's rotors)
Bill
Old Aug 9, 2003 | 09:44 PM
SVT_KY's Avatar
Looks that way ... Weren't they marked left and right?
Cliff
Old Aug 9, 2003 | 09:47 PM
J15BIG's Avatar
well thats 2 votes for wrong and 1 vot for right
Old Aug 9, 2003 | 09:48 PM
J15BIG's Avatar
Cliff
yeah they were marked on teh box. but we took them out of the box and set them down then forgot
Old Aug 9, 2003 | 09:54 PM
DaveRed99's Avatar
Thumbs up Oh no............
Look's to be you just wasted some Pad's !!!!!!
Old Aug 9, 2003 | 09:56 PM
hdmlnium's Avatar
Wink
If that is your front left wheel, then you have them on right. As the rotor spins it is designed to push out not push in. That isn't the best way to explain it but I tried.lol
Bill
Old Aug 9, 2003 | 09:57 PM
J15BIG's Avatar
it is my front left(driver side) wheel.....im very
Old Aug 9, 2003 | 10:00 PM
hdmlnium's Avatar
That is the way Stan told me to put them on and he explained it much better. I have had them on my truck that way for 2 plus years and about 4 to 5k miles with no problems. They are Stans rotors aren't they?
Bill
Old Aug 9, 2003 | 10:04 PM
J15BIG's Avatar
yup, they are stans rotors. so I have them on right! thank God...didnt feel like doing another brake job
Old Aug 9, 2003 | 10:48 PM
VinniePSVT's Avatar
When I first saw the name of this thread I thought you were talking about your S/C rotors. That would be one hell of a cluster****
Old Aug 9, 2003 | 11:35 PM
LTNBOLT's Avatar
Cool
You have them on right. It forces the hot gases out as the rotor is spinning. That's the way Stan explained it to me.
Old Aug 10, 2003 | 01:32 AM
Ayrton's Avatar
The cooling vanes inside the rotor should "whip" the air away from the center, not "bite" into it
Old Aug 10, 2003 | 10:53 AM
SVT_KY's Avatar
FROM THE BREMBO INSTALLATION MANUAL:
DIRECCION DE ROTACION DEL DISCO
Es un error bastante difundido el pensar que la
dirección de rotación del disco venga
determinado por ranuras o incisiones. En
realidad, para un disco con la zona interior
vaciada, la geometría de las palas que allí se
encuentran díctan la dirección de rotación.
Hay tres tipos de palas utilizadas:
• Derechas.
• Columna de palas (comprende muchos
postes pequeños).
• Palas curvadas.
Las dos primeras tipologías de palas no son
direccionales, y pueden ser utilizados en la otra
parte del vehículo. La pala
curvada , siempre es
direccional. Un disco a pala
curvada puede ser instalado
con las palas de giro desde
el interior hacia el exterior
del diámetro en la dirección
de rotación (ver figura).
La orientación del disco crea
una bomba centrífuga. La
rotación del disco crea una
corriente de aire que viene
bombeado desde el centro
del disco , a través de las
palas, y sale a través de la
parte externa del diámetro
del disco. Esta característica del disco permite
la disipación del calor.
Además, todos los discos incididos Brembo son
direccionales, sin tener en cuenta la forma
geométrica de las palas. Los discos suelen
estar instalados hacia el final de la ranura más
cercana al borde esterno del disco que se
encuentra en contacto con la pastilla.
(c) 2003 Brembo
