mixing wheel/tire sizes
has anybody got a 20x10 for the rear and a 20x8.5 for the front? I just don't like how the front looks like it sticks out of the fender a little. If so, what brand and size of tire have you gotten for those two wheel sizes?
thanks for your help,
josh
josh
ok, so maybe I'm just making things more complicated than they have to be.
Is there any noticeable visual difference in the height of the sidewall between a 275/45/20 and a 295/40/20? There almost the same right?
I'm just looking down the road in case I ever go to a 4/6 drop. I don't want any clearance issues. That's why i'm leaning towards a 20x8.5 wheel with a 275/45/20 on all four corners. I like the way the 295/40/20 sidwall looks, so that's why I asked the question...
thanks for any opinions
I have 20" Factory Replicas with taller tires in the rear. It gives the truck a "crouching" forward look. One small problem is that the tires can only be rotated left to right. Also, the ABS kicks in when braking hard.
The truck is now for sale, see the Classifieds.
Jeff,
Thanks for the reply. Can you give me some more info? How do I go about determining the correct backspacing? Also, what brand of tires are those on your truck? Did you get unidirectional tires so you can rotate them?
Thanks,
josh
Thanks,
josh
Originally posted by jlaird
Jeff,
Thanks,
josh
Jeff,
Thanks,
josh
jeff,
Thank you very much for explaining that to me. I think I understand now. So say I wanted to get a 8.5 inch wheel for the front. I currently have the stock L wheel. I want the new wheel/tire combo to not stick out of the fender as much as it does now. I'm thinking I want it to move back into the fender about an inch from where it is now. What backspacing should I get with the new 8.5 wheel? Hope that wasn't too confusing.
thanks,
Josh
thanks,
Josh
jeff,
thanks,
Josh
jeff,
thanks,
Josh
Jeff,
I was just checking out that tire tread. So, can you not rotate your tires?
Jeff,
