Accufab TB
Old Jul 28, 2003 | 10:39 PM
Jaxtoy's Avatar
Question Accufab TB
I am planning to install Accufab single blade TB. Do i need to reburn my chip for this mod!!!!!
Old Jul 28, 2003 | 10:46 PM
J15BIG's Avatar
no, you just need to check/set your TPS voltage. try a search.
Old Jul 28, 2003 | 11:33 PM
promodlightning's Avatar
I found that by setting your tps voltage to around a 1.06 seems to work heavenly.... Simulates more of a load on vehicle....
Old Jul 29, 2003 | 04:24 PM
tallimeca's Avatar
voltage
nothing over .999
Also, when installing it, lightly tighten all the bolts, they tie the throttle open and line up the t/b and plenum with your fingers so they are as matched as possible. Otherwise you will get the most annoying whistling sound.
