How often does the Intercooler Cycle?
Old Jul 28, 2003 | 01:30 PM
TampaBlack99's Avatar
Was told by the shop that the intercooler does'nt run all the time.
Have read on other turbo boards it's do to smog regulations, is this the same with our superchargers.
Mine stopped working all together, so I am trying to find other possible reasons for the intercooler pump failure other than the pumps motor just wearing out. My truck only has 50K miles.
Old Jul 28, 2003 | 01:40 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
From the factory, the intercooler pump runs whenever the truck is running.
Sorry 'bout your luck.
Old Jul 28, 2003 | 01:45 PM
Thanks, trying to get everthing fixed and not get hosed at the same time.
Intercooler pumps are hard to find and not cheap.
Old Jul 28, 2003 | 01:50 PM
LightningTuner's Avatar
Actually Speedy, the I/C pump is PCM controlled, and is turned on/off based on the IAT2 temp. Factory setting turns the pump on at 60 degrees, and off at 50 degrees. When the truck is stone cold, it usually takes the pump a few minutes to come on, but it should always be on with a warm engine. Before you condem the pump, I'd pull the IAT2 out of the manifold and make sure it's not fried, I've seen quite a few melted.
Old Jul 28, 2003 | 01:52 PM
I stand corrected.
Thanks for the clarification Sal.
Nice sig pic btw.
Old Jul 28, 2003 | 01:56 PM
Sal, where is the IAT2 in the manifold located so I can check it.
Thanks for the info.
Old Jul 28, 2003 | 02:01 PM
On a 99, it should be on the drivers side, towards the rear, May be a bit hard to get to.
Old Jul 28, 2003 | 02:03 PM
It's in the manifold not the mid plate right?
