Just got Lakewood Traction Bars NEED HELP!!
I just got a set of lakewood traction bars for the L. I put them on I can't seem to get the snubber lower I used the spacers like it says still no go. It's maybe just maybe a 1/8in from the spring eye. It's says I should run a 1/2 in for street use. Guys know of any way. Or should I cut the snubber a little.
Would this hurt anything to run it like this.
I took it for a test drive and it seems ok.
Brad
00L
Lakewood traction Bars
Belltech shackles
PSP 6lb Pulley
PSP Air Filter Kit
PSP FLIP chip
90mm MAF
Boost Bypass
Nitto Drag radials
Brad
00L
Belltech shackles
PSP 6lb Pulley
PSP Air Filter Kit
PSP FLIP chip
90mm MAF
Boost Bypass
Nitto Drag radials
Yea the fit is fione besides my snubber is only 1/8 away.
So would you just trim the snubber a little or try to get them down a little more.
Just how far away should they be???? from the eye
Brad
Brad
Is your truck lowered? I have the Lakewoods on mine and I have a 2" rear drop. I used 4 spacers per side just on the front and I have about a 3/4" gap. Mine rides perfect. So far my best 60ft. is a 1.82 which I know could be better with more practice. I only ran the truck with the bars 4 times.
