intercooler option
Old Jul 21, 2003 | 11:05 AM
charged99's Avatar
Arrow intercooler option
Ok my 99 is starting this intercooler bs. At least I think it is, the previous owner did not do the recall and I think it might be starting to get thirsty on the intercooler fluid. First off how much intercooler fluid usage is normal. Cause it was a little low when I got it on the road back in April and now its pretty close to the bottom. Second I talked to my friend that works at a Ford dealersship(SVT Certified) and he says that they now turned the recall into a TSB which I knew, so I would have to pay for it. HE said his cost would be about $650 for the intercooler and then he would do the work for $50. Is there any aftermarket intercooler that would fix this issue? Is there any other option?
Old Jul 21, 2003 | 11:55 AM
PoorSvtMan's Avatar
what exactly is the problem on 99 L intercoolers?
I bought my 99 L used.. what should i look for,etc?
Old Jul 21, 2003 | 12:03 PM
Crued's Avatar
0 usage is normal. Or 0 measureable usage that is. Sounds like it's leaking to me.
There is no aftermarket intercoolers available for purchase. There's been talk, but nobody actually has one for sale. My advice would be to watch ebay and pick up the revised one up on there.
Old Jul 21, 2003 | 12:04 PM
Nathan's Avatar
The fins on the intercooler would weaken at the joints and leak coolant into the intake. Normally, you should not lose any coolant from your IC reservoir. On my 99, I was losing up to a gallon a week with only moderate driving. To my knowledge, there are no aftermarket replacements (I'm not talking about the heat exchanger in the bumper). If you are seeing regular fluid loss, switch to water in the the IC tank to avoid clogging up your 02 sensors andd making life more miserable. Then get thee to a dealer and get it fixed !
Old Jul 21, 2003 | 12:06 PM
charged99's Avatar
ok thanks guys looks like I will just go for it so I dont have to worry about it.
Old Jul 22, 2003 | 01:08 AM
PoorSvtMan's Avatar
So what exactly should i look for? will the resivor get low or what?
Sorry im a newb so flame me if ya want. My truck will be out of the body shop (damn old lady driver) and i want to make sure mines ok,etc
Old Jul 22, 2003 | 01:21 AM
WHITE01XXX's Avatar
Yep itl get low dude.
Old Jul 22, 2003 | 01:24 AM
JeffsLightning's Avatar
Take a black marker and draw a line on the side of the IC tank..You will notice a drop in that level plus you should be able to smell burning antifreeze...Hope this helps.. Good luck...
Old Jul 22, 2003 | 03:31 AM
Flying Mofo's Avatar
Banned
Contact Spearco if you need a new intercooler core to into the lower intake. Probably cost you the same as a replacement ford unit.
