fuel pump problems
Old Jul 14, 2003 | 06:08 PM
on the rocks's Avatar
fuel pump problems
My dealer has just informed that my fuel pump is shot in my 99L and a new one is around $900 canadian plus $700 labour. Is there any aftermarket pumps that I can get cheaper?
Old Jul 14, 2003 | 06:10 PM
easterisland's Avatar
If you have a few tools you can do the switch out yourself. Sal sells 255 pumps for $300 a pair. What's that about $2000 Canadian, eh?
Old Jul 14, 2003 | 07:24 PM
So you are saying that there are 2 pumps in the tank. How does a guy get ahold of Sal, does he have a website?
Old Jul 14, 2003 | 07:44 PM
I was driving the truck the other night and it just stalled and then would start and idle rough when I hit the throttle it would stall again. Does this sound like the fuel pump(s) are gone? This is what Ford says is the probelm.
Old Jul 15, 2003 | 12:12 AM
If I decide to go with high volume pumps do I need to get my chip reburned?
Old Jul 15, 2003 | 12:15 AM
Probleminfected's Avatar
our trucks fuel tank is super easy, you need some fuel line disconnect tools and a basic socket set. take about 2 hours. make sure there isn't that much gas in the tank, or it might be a little more hard to do
Old Jul 15, 2003 | 09:11 AM
MaxPower's Avatar
I had the same problem - the connector on my low speed fuel pump cracked and wasn't providing enough fuel. They replaced the whole pump. This was on an '01 with only 28k miles
Old Jul 15, 2003 | 09:32 AM
LightningTuner's Avatar
Here you go, no chip reburn needed:
PSP High Volume Fuel Pump Kit
Old Jul 15, 2003 | 10:48 AM
Thanx for the help and info.
Old Jul 15, 2003 | 10:57 AM
Just one more question, if one of the pumps fails would the other not be able to keep the truck running?
Old Jul 15, 2003 | 11:52 AM
MaxPower's Avatar
Somewhat...it'll run/idle like a pig.
Old Jul 15, 2003 | 12:07 PM
casper lightning's Avatar
www.RPMoutlet.com has 255lph Walbro pumps for a Lightning for 198.xx.
Old Jul 15, 2003 | 12:28 PM
Are those the 3342's? Is a plug and play deal or more a cut the stock wiring and use a new different wire harness?
Old Jul 15, 2003 | 08:00 PM
Don't know. I just seen it the other day. It looks like you'll have to cut the factory harness.
Old Jul 16, 2003 | 10:25 AM
So, if I have one bad stock fuel pump and decide to change it out with a higher volume pump do I need to change the other stock pump?
