658hp/792lbft
Old Jul 15, 2003 | 08:57 AM
teamSLS's Avatar
To all:
I guess I should have said:
I bought the PARTS from Sal, the engine assembly was completed "in house."
Centerline Machine in Amesbury, MA did the balancing and boring.
The heads came pre-assembled, with the exception of the cams and followers...which I did myself as well.
The N-Tercooler does work well for dyno situations (no air movement) I have yet to use it on the track/street. The electric fans behind the exchanger are an awesome upgrade esp. when combined with spray bar. I decided to try this because I had everthing I needed from previous kits, so I just had to buy the bar itself...which was inexpensive.
The new head gaskets are key to making this power, FYI. The old 2-piece are crap.
I drive this truck everyday...so I guess it's streetable but, its tough not to be a menace
see ya
Andy
Old Jul 15, 2003 | 10:11 AM
blown318's Avatar
nice numbers.....
Old Jul 15, 2003 | 10:26 AM
cpeapea's Avatar
great numbers!!!
Old Jul 15, 2003 | 11:10 AM
69Roadster's Avatar
Sweet. Good to see another 'hands on' guy on the board. Also good to know it IS possible to build your own engine and have it run . Really the only thing I am worried about is the cam timing. I've built plenty of pushrod motors, this is my first overhead cam build though.
Originally posted by CHIKIN1
Yeah, just don't blow this one up j/k
Yep that's my worst nightmare. The first engine was built by MTI and was in the truck when I bought it so at least it didn't break due to my mechanic skills. And it really didn't blow up, just dropped a valve. Still did a lot of damage though.
Old Jul 15, 2003 | 11:31 AM
easterisland's Avatar
Originally posted by andrewjhaley
I'd like to see the interior. I've always wanted to see the Milano's in the L
Here is a pic of Milanos. Now if I could just make that much power...
Old Jul 15, 2003 | 11:41 AM
Don's Bolt's Avatar
Thumbs up
Andy looks like you have a awesome setup there. Since we are close to each other, we should meet up and compair mods. I am interested in your N-Tercooler setup, and I am sure I may help you with a few things too.
Have you had it to the track yet, and what are/or plan to run for slicks. If you haven't modified your rear brakes yet I can show you what I had to do to get 15 inch slicks to fit on mine.
Give me a call
781-983-6677
Don
Old Jul 15, 2003 | 02:29 PM
kylightning's Avatar
sweet mother of power..........wow
Old Jul 15, 2003 | 03:03 PM
Bad as L's Avatar
And the bar just keeps going higher Great power Andy !!
Dale
Old Jul 15, 2003 | 07:33 PM
reality1's Avatar
Awesome #s
I too am interested in your N-Tercooler setup. Could you please describe how you set it up?
Old Jul 16, 2003 | 08:58 AM
teamSLS's Avatar
Hey all-
the NX N-Tercooler is a piece of cake.
I have a 15 lb bottle in the bed, running the line through the frame.
A purge selonoid (had laying around) with the outlet instead connected to the spray bar.
right now, I have the switch under the hood with my fan, exchanger fans and intercooler pump. My intention is only to ice it between drag/dyno runs.
I am almost positive that "driving down the street" gains would be minimal at best...if it was air to air, it'd be a different story--which was the original purpose of the kit.
Brought my fluid temps down from about 123 or so to 91 in about a minute thirty, sitting stationary with the heat exchanger fans on/pump running/engine off. The bottle was not on the entire time, just giving it "shots."
Fluid temps checked with a laser thermometer, BTW. So some degree of error should be assumed.
If purchasing the kit, delete the bottle (a 5.5lb) and go to a 10lb minimum...the hot fluid eats through the gas.
still testing...will provide info as it comes.
Old Jul 16, 2003 | 10:15 AM
MaxPower's Avatar
Mods: everything
Nice! ...man, I wish I had the time/money to build a menace... What's the Powerball back up to??
Old Jul 16, 2003 | 12:55 PM
St Louis Lightning's Avatar
14 Million and it's MINE! ALL MINE!
