next mod
Old Jul 14, 2003 | 01:46 AM
s.cal L's Avatar
next mod
I want to get a Kenne Bell S/C for my next mod. This are my mods right now, 2000 L: JLP Diablo chip , 5# lower, 2.7 upper, single blade t/b, 90mm maf w/12" filter, stock exhaust w/ no cat convertors, 3:73 gears, line mod valve, elec. fan, 160 thermo. The chip is burned for race fuel, I use F&L 111 race fuel. It has 26,300 miles on it. My question is how would my L run with a 5# lower a KB and the rest of the mods that it has?
Old Jul 14, 2003 | 07:13 AM
Flying Mofo's Avatar
Banned
Eventually youre going to have to build that shortblock to handle the power the new blowers are putting on them.
If it was me, i would build the shortblock first.
Old Jul 14, 2003 | 10:38 AM
s.cal L's Avatar
At 26,000 miles the motor is in good shape, ill do that once it hits 50,000 or more. Its not a daily driver and ive seen it done on stock blocks. Im asking how would it run performance wise.
Old Jul 15, 2003 | 01:02 AM
promodlightning's Avatar
If you run your 5# lower with the biggest KB upper (a 3.5) you will have 15# of boost, might be a bit much due to the greater efficiency of the KB...You could just put a good set of rods in your motor and be safe....Im finding that with these KBs and 140s, you will end having to get bigger fuel pumps and injectors and a real good tuner to get you decent dyno numbers.
Old Jul 15, 2003 | 01:13 AM
WHITE01XXX's Avatar
mucho mulla dude.
That combo your talking about will not last long on that stock bottem end.
And its not the rods that i worry about with big boost situations on these trucks its the heat at the piston that caused my failures.
If you get a tune with no detonation then the rods are not a problem, but 15-16 lbs of boost rom a KB will cause plenty of heat on these stock pistons and the rings cant handle it, they melt and thats that
