Weird smell?!
Old Jul 13, 2003 | 09:07 PM
chiketkd's Avatar
Weird smell???
I've owned my 2000L for 6 months now, and every time I bury the gas pedal to the floor for more than 10 seconds, I get this weird smell that fills the cab.
I've had my dealer keep the truck for a day and look it over completely, and everything was running perfectly. The smell still persists.
It doesn't smell like burning oil, and for the longest time I thought it was supercharger fluid that was burning off. It could also be moisture being burnt off the block or supercharger.
Is this smell common among other L's? Thanks!
Old Jul 13, 2003 | 09:11 PM
YtDiamond05's Avatar
i have a 2000 too and mine has the same smell, i dont know what it is, but i know tha smell ur talking about. ive jus lived with it and havnt worried about it, but maybe somebody else will fill us in.
Josh
Old Jul 13, 2003 | 09:12 PM
promodlightning's Avatar
Probably the undercoating or something....or someone ran something over.....
Old Jul 13, 2003 | 09:14 PM
chiketkd's Avatar
exactly...it's definitely something you can live with. My wife barely detects it when she rides with me. I know it's not like an overly powerful smell...but it's a perceptible smell alright.
Old Jul 13, 2003 | 09:16 PM
chiketkd's Avatar
Nope. It's not anything I ran over. I had my dealer change the oil on the truck yesterday, and the underside of my engine block is clean as a whistle.
Old Jul 13, 2003 | 09:29 PM
FooFur's Avatar
i also have "the smell" after i get on it hard
Old Jul 13, 2003 | 09:59 PM
NateTrun2's Avatar
probably head gaskets seating or leaking. <--- common problem. mine has a slow leak on the passenger side.
Old Jul 13, 2003 | 11:48 PM
VyPeR's Avatar
blower belt slipping a bit?
Old Jul 14, 2003 | 11:00 AM
FooFur's Avatar
i kinda like the smell anyway
Old Jul 14, 2003 | 11:23 AM
MHMCGILL's Avatar
Try dumping some A/C deoderizer in the A/C system. Sometimes the mold gets dislodged under WOT and hence the smell. Just a thought but most undetermined smells do come from the A/C system. Good luck.
Old Jul 14, 2003 | 12:29 PM
BlownSVT's Avatar
I also get that smell after rippin on it.
Old Jul 14, 2003 | 01:24 PM
chiketkd's Avatar
Called FORD SVT
I called 1-800-FORD-SVT and described the smell to them. I was told the following:
Check the dipstick on your engine. If the oil is 'at' or 'above' the max fill mark, under WOT oil from the engine may come up into the intake.
Solution: Remove the intake tube from the filter/MAF sensor and with a clean cloth wipe the inside of the tube completely. Smell should be gone completely.
I was also told that if the smell ever turned to an 'anti-freeze' like smell, then it could mean that there is an engine or intercooler coolant leak.
The smell is nothing to worry about though!
Old Jul 14, 2003 | 07:43 PM
chiketkd's Avatar
SVT was right!
After driving my truck home this afternoon, I let it cool for 45 minutes before taking the intake tube apart and checking for the oil.
At first glance I saw none, but on further inspection I found oil collected in the bottom part of the little ridges of the intake tube just behind the MAF sensor. I was surprised by the amount of oil collected, and it took me three shop towels to totally clean everything out.
Interestingly enough, there was none at the top of the tube near the opening to the supercharger, but all of the oil had collected in the ridges by the bottom.
I won't know if the 'smell' is gone until I drive the truck to work tomorrow morning. I'll check the intake again this coming weekend to see if anymore oil starts to accumulate again.
Thanks SVT!
Old Jul 14, 2003 | 08:32 PM
cpeapea's Avatar
my 01 gets it, i think there is a super old post from like 99 about it. something about an acrid smell. i think it was the tensioner
Old Jul 15, 2003 | 12:31 PM
chiketkd's Avatar
When driving at 70mph on the interstate this morning going to work, I buried the gas pedal several times and the 'smell' was totally gone. Problem fixed!
