parking brake adjustment
You might have to jack the truck up a lil bit if your not a twig like me...but anyways, if ur under the truck, there should be a little black rubber tab the size of a thumbnail on the reverse side of the dust plate and underneath the axle....just peel it off and there should be a gear that can be turned with a flathead...I'm petty sure that cranking it down loosens it. Hope tis helps, if not just ask.
Re: NOT SURE CALL FORD
Originally posted by tlfwatch
NOT FOR SURE/ CALL FORD TO BE SAFE
