Plug wet with fuel, why?
Old Jul 10, 2003 | 01:11 PM
Crued's Avatar
My old #5 plug is crusty. My new #5 plug is wet with fuel. I tried replacing the coil pack, and it didn't change anything. Tonight I'm going to replace the injector. If it wasn't the injector... What else would cause a plug to be wet with gas?
Old Jul 10, 2003 | 01:30 PM
1BADTK's Avatar
Not firing, make sure the tab inside the coil pack isnt bent and not plugged in.
Old Jul 10, 2003 | 04:37 PM
PWR_WHLS's Avatar
a thought?
Leaky injector.
John
Old Jul 10, 2003 | 04:45 PM
grinomyte's Avatar
Re: a thought?
Originally posted by PWR_WHLS
Leaky injector.
John
I was thinking he might be right, i mean if he had a solid misfire the engine would throw a code and run poorly as well, he made no mention of this. Ive never heard of an injector leak personally, but i suppose it happens.
Old Jul 10, 2003 | 08:16 PM
Crued's Avatar
well, i replaced the injector and i have same symptoms. there are no codes being set, and my autotap reads 0 misfires. but yet, i pulled the plug yesterday, and it was wet with gas. i did not pull the plug after the new injector, cause i'm too fed up with it right now.
anybody got an idea?
Old Jul 10, 2003 | 08:20 PM
svt4rd's Avatar
possible pcm commanding the inj open longer than possible. if you have an obd 2 scan tool monitor your injector fault pids and see what you get... its a starting point anyway.
Old Jul 10, 2003 | 08:27 PM
grinomyte's Avatar
wait wait, you didnt mention any symptoms, you just said your plug had fuel on it. Now you replaced your injector, you should run it some and check the plug again, if its clean problem solved, if it isnt, then on to the next possible solution.
Old Jul 10, 2003 | 08:30 PM
Flying Mofo's Avatar
Banned
Have you noticed any excessive burning of oil? If so, your valve guide may be shot as well besides an injector thats not completely turning off. Only thing i can really think of. h
Old Jul 10, 2003 | 08:32 PM
grinomyte's Avatar
oh and number 5 is the passenger front plug right? Are you sure its fuel, i once had that plug and the plugs behind it coated with oil. I freaked when i saw the first one thinking i have done some major damage, but it turns out i just dont know how to use a funnel to fill up the oil.
Old Jul 10, 2003 | 08:41 PM
Crued's Avatar
#5 is front drivers side.
I changed the injector with a new one, so the injector is not stuck.
I'm 99% sure it's fuel on the plug... It's not dark to be oil, and no green tint, and it smells like fresh gas.
The symptom I'm having is some sort of misfire/stumbling. It's not horrible, but something is definately happening. It's most noticeable when you hold the throttle say at 15%, you get a little burble in there at a pretty regular interval. Also when you jab the throttle and it's coming down you get burbling. (This would be operating the throttle from the engine compartment).
Old Jul 10, 2003 | 09:21 PM
Blue02svt's Avatar
Have you checked the volatage going in to the pack?
Old Jul 10, 2003 | 09:28 PM
Crued's Avatar
No, but I can. What should it be?
Old Jul 10, 2003 | 09:33 PM
Blue02svt's Avatar
I dont know, but i am just wondering if the pack is getting any power. Break in the wire, grounded out, weak voltage, etc.. Im sure someone on here knows the voltage etc..
Hey maybye you could pull the pack (not the plug) Put a plug in the pack, ground the plug , and do the oldschool spark test ??
Old Jul 10, 2003 | 09:42 PM
hslightnin's Avatar
old school wold be to hold the plug while testing it
Old Jul 10, 2003 | 09:44 PM
Crued's Avatar
I did pull the plug on the pack while it was running and the got constant misfires, so I know it's doing 'something'
