What are these mystery boxes?
HI!
NEAL knows!
quote from Neal:
"The small rectangular shaped black box behind your battery is actually a vacuum resivoir for storing vacuum to operate your climate controls when your truck is not running. I removed mine with no after effects. You just can't use the climate controls when the engines not running. Like who would want to anyway?"
from this thread: https://www.f150online.com/forums/sh...hreadid=115669
about halfway down the page..
NEAL knows!
quote from Neal:
Originally posted by clonetek
HI!
NEAL knows!
quote from Neal:
HI!
NEAL knows!
quote from Neal:
Thanks, Clonetek. I even had a post on that page. Duh. It's either the old age or the bong hits.
I took both mine out along with 4 FEET
of vacuum hoses running all over the engine bay for the boost dump solonoid and just capped it off. It is so much cleaner now, and i took off all that loom crap off everything too with all that sticky tape. Will be relooming the visible lines soon.. Just remember to keep vacuum running to the line going into the firewall for the climate controls...its behind, underneath the starter solonoid.
The top mystery box is a vacuum reservoir for your a/c system. The bottom one is for your e.g.r. system. They store vacuum to keep your air that comes out of the dash when in the a/c mode or vent mode to remain operational when you have no vacuum. Otherwise the air comes out from the defroster vent or the floor like when the heater is on. The one for the e.g.r. stores vacuum so that the e.g.r. valve doesn't open or close when it's not supposed to. Your vacuum goes away when accelerating or going uphill. These store your vacuum for those times when it is needed.
