1/4 mile, Heat and performance?
Old Jul 5, 2003 | 10:02 PM
todd abbott's Avatar
Question to all regular 1/4 mile folks - ballpark figure, what's does you truck lose for ET and MPH on a 90 degree plus heavy humidy day vs. 70 degree low humidity day, I know theres no solid awnser to this I'm just looking for your experance. I couldn't break into the 12's today and frankly was a bit disappointed, I figured with my mod list even with the heat, consistant upper 12's would be no problem, as I ran mid 12s earlier in the season and then added a full exhaust, loop, traction bars and had it tuned. The truck was just a dog all day and was effected by the heat thats a given but a second off of my expected ET? Thanks, Todd
4lb pulley
Kook long tubes, high flows, magnaflow cat back
accufab T/b
chip
fan and water pump
FTVB
traction bars and loop
ram air kit
Old Jul 5, 2003 | 10:05 PM
JewishLightning's Avatar
I'm almost sure that there is a correction factor for heat and humidity. I think the NHRA website has the formula or just do a google search.
Old Jul 5, 2003 | 10:10 PM
Found it,
http://www.csgnetwork.com/relhumhpcalc.html
Old Jul 5, 2003 | 10:53 PM
Johnny AC's Avatar
Performance
I've seen as much as 3 to 4 tenths difference in the Q-mile from the best to worst weather conditions with my 2000 L . I don't race very much in the Summer months, mostly in the Spring and the Fall. John H
Old Jul 6, 2003 | 12:09 AM
air1kdf's Avatar
That doesn't apply to an intercooled engine as much as it does a naturally aspirated one.
My ET's dropped 1 tenth per 7 degrees.
My truck also had much slower times due to heat recently. So I have 2 intercooler fans and a JDM phenolic spacer to put on.
The intercooler temps were so high that I was barely able to touch the tank. The same holds true for intake.
It's hard to imagine that that real hot fluid cools the intake flow.
Old Jul 6, 2003 | 10:07 AM
Thanks guys, That's a great link, Todd
