100 shot of nitrous... is it safe
Old Jul 1, 2003 | 07:34 PM
stang46sc's Avatar
Arrow 100 shot of nitrous... is it safe
Ive got an 01 with only a FTVB no other mods. How is it that people are running 4 and 6 # pulleys along with a 50 to 75 shot of juice, but when i mention im gonna be using a 100 shot with no xtra boost im always told its not gonna hold. I am gonna get a flip chip tuned on one side for the juice and have the timing and shift points lowered. I think this would be safe. You never hear of the trucks blowing pistons, they just break rods. So if i just pull the shift points down to around 5200 or so that would take some of the stress off the rods, right? Well, thats the way i see it anyways, but i could be wrong.
Old Jul 1, 2003 | 08:41 PM
Lightning Boy's Avatar
CLICK HERE --> <-- CLICK HERE
Old Jul 1, 2003 | 08:44 PM
cyntaxx's Avatar
Re: 100 shot of nitrous... is it safe
Yep you go the right idea. I know some shooting a 100 shot without any problems. Just don't spray from every stoplight on a daily basis.
Old Jul 1, 2003 | 09:36 PM
1BADTK's Avatar
I would not spray an 01, look at the blown motor post, 80% were 01"s. Blow the motor 1st, get a reman and spray it
Old Jul 1, 2003 | 10:06 PM
casper lightning's Avatar
I have a 100 shot and a 4# pulley with no problems. But I also have a 99 Lightning
Old Jul 1, 2003 | 10:39 PM
stang46sc's Avatar
Im not gonna be juicing it all the time, just when its needed. I know all about blowing motors, Ive put three in my stang in the last 3 yrs. So im just gonna spray on special occasions. I just figured that if the stock rods are good up to about 500hp at the flywheel then it shouldnt matter how you pick up the power.
Old Jul 2, 2003 | 08:30 AM
stang46sc's Avatar
ttt
Old Jul 2, 2003 | 10:36 AM
easterisland's Avatar
Sal is burning me a chip for a 100 shot and 18psi boost...
Old Jul 2, 2003 | 01:28 PM
Flying Mofo's Avatar
Banned
You got traction problems as it is
You going with 15 inch slicks now or what len?
Old Jul 2, 2003 | 01:34 PM
My best time with nitrous is .2 seconds slower than quickest w/o. I am in the process of looking for some new wheels. I hate to grind the calipers because I drive the truck all of the time.
I was hoping to pick up the ones stolen from Don C at a discount...
I'm tired of having a ten second truck and it only going 11's because of traction.
Old Jul 2, 2003 | 01:42 PM
Banned
How do you have your front suspension setup and what are your 60s?
If you go easy and not create a lot of heat, you will have no problems shaving the calps down. Take your time.
Old Jul 2, 2003 | 02:08 PM
My best 60 ever is a 1.69 with a 2600 stall.
I could do some suspension work, but I'm not going to. I have the roush suspension. I guess I could get the QA1 shocks and adjust them...
Is everyone else still using the front springs off of a regular F150 and QA1's in the back?
Maybe I'll just widen the wheels and see what she does...
Old Jul 2, 2003 | 02:29 PM
Banned
Try unbolting the sway bar, should help a bit.
How much air are you running in the tires and are the side walls screwed to the rim at all?
Old Jul 2, 2003 | 02:45 PM
soap's Avatar
***** Leonard I got 1.69's in my slow L...........you surely should be getting 1.5's with the power your making
Just ET Streets (no tubes/screws) and Truck Traks
--Joe
Old Jul 2, 2003 | 03:01 PM
I'm not going to screw the slicks because they don't move. That was at around 4600 pounds. With the sway bar disconnected...
