Polished Blower Installed
Old Jun 30, 2003 | 10:44 PM
Suavy's Avatar
TampaBlack99,
That thing looks great! I guess were from the same tribe!
Old Jul 1, 2003 | 07:33 AM
soap's Avatar
Originally posted by BDAZSVT
Looks great!! Are you going to do the upper intake next?
Just a guess...........he wants it like that. Contrast is a good thing
That's the upper off a Harley..........I think
--Joe
Old Jul 1, 2003 | 08:48 AM
TampaBlack99's Avatar
Bought an extra Plenum from RobG, so I can finish this one which has had the ridges removed and is completely smooth inside. Also I have just bought a ProPipe from SilverBolt to finish off the whole engine. Another big project has started also, gonna completely smooth a 01 lower manifold and mid plate inside and out. Polishing sucks, but in the end it's all worth it.
I have issues my girlfriend says I need to deal with.... it's never enough!
Old Jul 1, 2003 | 09:01 AM
QKSILVR's Avatar
Well, I ordered the 15mm cause someone told me I needed that size.
Old Jul 1, 2003 | 09:51 AM
Find yourself some steel reinforced pcv 3/8 tube, it's what soda dispencers use.
STOCK TUBE THAT COMES WITH THE KIT WILL SUCK FLAT FROM THE VACCUM!
I went to Home Depot and got some thicker walled 3/8 pcv tube until my steel reinforced stuff arrives.
You can use the 15mm version, all you have to do is find adapters to go from a 15mm to a 9mm hose. I have found the rest of the hardware to mount the can correctly and will post pics next week with the final results. All hardware will eventially get sent out to be powedercoated black when I am happy with the install.
http://www.sisweb.com/vacuum/sis/steelhos.htm
