ice bags
Old Jun 30, 2003 | 12:08 AM
promodlightning's Avatar
ice bags
be carefull ith the ice melting water down to your intake, coil packs are verticle, I fried two of my coil paks this way.....
Old Jun 30, 2003 | 12:14 AM
cyntaxx's Avatar
Yep, most recommend using a towel to soak up the dripping water.
I mostly rely on my efan and Meziere's for a quick cooldown
Old Jun 30, 2003 | 12:19 AM
LatemodelRacer2's Avatar
I always wrap a towel around the bag of ice it prevents the water from driping.
Old Jun 30, 2003 | 12:49 AM
VinniePSVT's Avatar
promodlightning- You live in Boynton? I live down in Boca. We should meet up sometime. There are some great Lightning guys down here.
BTW- You seem to have one hell of a powerful truck.
Old Jun 30, 2003 | 03:46 AM
Flying Mofo's Avatar
Banned
Get a hold of CobraYankee and get his maxcool thinger. Works pretty good without the mess. Uses those gel packs that you freeze.
Old Jun 30, 2003 | 08:23 AM
FooFur's Avatar
in your mod list - REM mondo intercooler w/dual spal electric fans
rem sells a replacement intercooler ?
Old Jun 30, 2003 | 11:33 AM
cyntaxx's Avatar
That's what I was wondering. Or is it a heat exchanger?
Old Jun 30, 2003 | 11:42 AM
blowntruck's Avatar
Yep. Those max cools are the *****.
Old Jun 30, 2003 | 11:43 AM
blowntruck's Avatar
http://www.maxcoolonline.com/
Old Jun 30, 2003 | 01:05 PM
vinniepsvt
Id love to hang out with you vinnie, my warehouse is in Boca across from FAU on nw 2nd ave...a lot of my time is spent at Razors Edge in Margate being the guinee-pig on all experimental Lightning parts and mods...my biggest problem now is my stock eaton is overspinning so much that its just making hot air at 19 pounds of boost...I am now experimenting mixing my water injection with ethanol alcohol and denatured alcohol at 50/50...Im usually at Razors Edge every saturday....Pete
Old Jun 30, 2003 | 11:03 PM
owheelies's Avatar
Pete,
I still thing your big brown truck is dreamy......but that's just me!
Eric
Old Jul 1, 2003 | 01:21 AM
big daddy Eric
I like to leave the big brown as far away from me as I can......as for the above mentioned "mondo intercooler" it is the heat exchanger for the intercooler...REM sells them now , they have more surface area and hold about 1 gallon more of fluid wich acts like a temperature stabilizer..I just bought the 2 spal electric fans and put them on to help out with the cooling in the city...my eaton is just making too much heat and until I get the KB, I will be experimenting...but i have heard of no dyno numbers on the heat exchanger yet.....
Old Jul 1, 2003 | 02:13 AM
NCETRY's Avatar
Damn Pete you are seeing 19#'s of boost. I am running the same pullies and only get 16.5#'s boost. We have almost identical setup's. Ask Paul about it. Are you running stock injector's? I have Holley 50# injector's on mine. I hope to dyno by the end of the week. Sick setup
