The Masterpiece.
Old Jun 30, 2003 | 05:43 PM
  #31
SVTRobG's Avatar
easter,
Just upstream of the air filter there's the maf adapter that's welded to the pipe then a hole gets drilled and the electronics bolt up directly to it.
You can see it here in Silver-Bolt's 1st picture.
Old Jun 30, 2003 | 05:50 PM
  #32
easterisland's Avatar
I can see the bracket on silver-bolt's setup. I just don't know how the mass air flow system works. I was thinking the sensor somehow measures the air which passes it. Since the air tube is now bigger than stock and the sensor is the same I would think it couldn't measure the increased air flow and therefore you would run leaner. Maybe I'm wrong, I probably am. I'll be doing some searches to look up some information so I'll have a little bit of an idea of how this works.
Old Jun 30, 2003 | 06:30 PM
  #33
SLV_BLT_PDX's Avatar
STi
Silver-bolt,
Where you planning on getting your STi? Are you looking at MSRP or did they mark it up?
STi would be nice to have.....
Old Jul 2, 2003 | 09:54 AM
  #34
Silver-Bolt's Avatar
More than likely the STi will come from Hanna's in Vancouver. I have them looking for a silver/silver combo. I may have to wait but I am in no hurry. Under msrp.
