Swap PCMs with no need for PATS programming
Old Jun 26, 2003 | 02:40 AM
mswaim's Avatar
Originally posted by easterisland
They have my pcm for how long? Can they guarantee a perfect tunr the first time or do I have to send it back again? Can They bypass Pats?
I run 26 psi with race gas and high timing, 20 psi daily and 15psi with a 150 shot of nitrous with race gas.
Will their reprogram learn all of that?
The program won't have to, they will simply supply it with the necessary data just as any chip would do. The only difference is it would be a more flexible program, adaptable to external pressures such as weather, fuel quality, etc.........in theory, if I understand it correctly.
Old Jun 26, 2003 | 09:19 AM
ShadowBolt's Avatar
Steve and Twisted. Are you saying you are able to use either PCM in your truck and they both will work?
Jerry
Old Jun 26, 2003 | 09:57 AM
jmlay's Avatar
Thanks for the info Sal. Hope this does not go off track now...
Mike
Old Jun 26, 2003 | 10:53 AM
jagged edge's Avatar
Originally posted by TheSilverBullet
why dont you send those extra PCMs to BOP and quit wasting time on chips...
think outside the box.
Un-called for. BOP doesn't need this kind of promotion.
JE
Old Jun 26, 2003 | 08:10 PM
Twisted99's Avatar
The dealer took my new longblock for a test drive with the PCM in it that they say was tampered with.
Road tested and told me everything was fine...
They then installed a new PCM and told me that my warranty was voided.....
Because the truck was run previously with the so called tampered with PCM...
The same one that they used to road test the new longblock with...
Funny if I drive it with the original PCM..which is what they based the warranty denial on,....Then they use the same one to test drive the new stuff with......But..get this I have a warranty now because the new PCM was installed after The test drive with the old PCM....
Yes they had a key of mine and yes they installed the new PCM..and yes I can swap back and forth without any problemss....and the PATS works.
But ......My warranty doesn''t..according to.......well you see my point.
When I point out that if the original PCM used voided my warranty..then doesn't the use of the same original PCM void the warranty on the new long block....
Well..I get a dazed and confused look....
Old Jun 27, 2003 | 12:50 AM
Calightnin's Avatar
Yes, Jerry...I interchange them at will.
Steve
Old Jun 27, 2003 | 02:39 AM
Tundra's Avatar
Rest In Peace
From: anchorage, alaska, usa, north america, earth, solar system, milky way
Twisted, have you won the battle yet?
My hat is off to you for standing up in what you beleive in.
Old Jun 27, 2003 | 07:41 PM
Twisted99's Avatar
I have just recieved a call from my Criminal Lawyer...
laughin`....
My prelimienary Trial is set for July 11.
Old Jun 27, 2003 | 07:48 PM
Flying Mofo's Avatar
Banned
Dont be a tier bitch bro
First guy that asks to see your " paper work ", be prepared to bomb on his ***.
Old Jun 27, 2003 | 10:22 PM
Tim Skelton's Avatar
Re: Swap PCMs with no need for PATS programming
Originally posted by LightningTuner
. . . Due to the recent onslaught of unfair and bias warranty denials by Ford, we are now offering the customer the means to have a spare PCM, . . .
Old Jun 28, 2003 | 08:44 AM
Rob_02Lightning's Avatar
WAY TO GO SAL
Your always thinking, I LIKE THAT
Hey I got a question FOR ALL
We all know Ford has taken back hundreds and prob thousands of lightning's on trade in's THAT HAVE HAD Chips in them pryer to turn in.
What happens when they re-sell them, and then the new owner (who doesn't know or never chipped it themself) comes in for wrrnty service ???
Old Jun 28, 2003 | 09:43 AM
air1kdf's Avatar
Sal,
I may have missed the point. But, can you do the same burn as the dealer with PATS enabled?
