Torq specs on Blower nose bolts?
Old Jun 24, 2003 | 02:14 PM
TampaBlack99's Avatar
Does anyone now the torq specs on the stock L blower nose bolts? Need to put my polished blower together soon, thanks.
Old Jun 24, 2003 | 02:32 PM
captainoblivious's Avatar
I'm not even sure if I torqued my blower down that much when I re-installed it Think I just did hand tight plus a little more.
[edit] read you post all wrong [/edit]
Old Jun 24, 2003 | 02:52 PM
SVT_KY's Avatar
I can check it when I get home ..
Old Jun 24, 2003 | 10:51 PM
SVT_KY's Avatar
Sorry it took so long
Super charger pulley adapter bolts - 35 ft lbs.
That's the only one listed that makes sense ...
The "auxilliary crankshaft pulley" says 74 ft lbs ...
The caged pulley brace nuts are 35 ft. lbs...
Old Jun 25, 2003 | 11:16 AM
Ignore my first post, I read your post all wrong the first time, for some reason I though you meant the bolts that attach the blower to lower plenum.
I believe when I put my blower back together I used 24ft lbs. to attach the snout to the main casing.
Old Jun 25, 2003 | 11:29 AM
Sooo somewhere inbetween 24-35.
Gonna take a torq wrench and see what the bolts are tightened to on my effphed up blower I will be removing this weekend.
Thanks for the info!
