Riechard pulleys
Old Jun 24, 2003 | 06:07 PM
Ayrton's Avatar
Originally posted by Jeff's Bolt
www.modularfordpowerhouse.com
That is where I got mine....
Old Jun 24, 2003 | 07:42 PM
easterisland's Avatar
Originally posted by alphadoggy
Offhand does anyone know the stock pulley diameter on the K.B? (I don't have access to mine right now?) And would switching from a stock to a 2.7 require a new drive belt?
I think they come with 3.5". That is what mine came with on the snout. If you don't have one of the tools you may need one to remove the pulley. I would think switching from a 3.5 to a 2.7 would require a new belt. What size lower pulley do you have. If you have a stock lower pulley and and 2.7 upper that is a lot of boost unless you have a built engine. I get 22 psi with a 2lb lower and 2.5" upper.
Old Jun 24, 2003 | 07:57 PM
alphadoggy's Avatar
Thanks, Easterbunny. Wow, that is a lot of boost for a 2 lb. pulley. I have a 6 lb. lower, and according to KB that should yield about 18 lb. of boost with the stock upper pulley. I do have a built bottom end, and am looking for about 22 lbs. with the JDM ported heads. Maybe a 3" pulley would do the trick, what do you think? Plus I think I'd be less likely to encounter belt slippage with the 3", huh?
Old Jun 24, 2003 | 08:06 PM
People get different amounts of boost from the same pulley size.
I get 26psi with a 6lb lower(8.9") and 2.5" upper and 15psi with 6lb lower and 3.5" upper.
I just ordered a 3" upper from Tom this morning. I am hoping to get 20psi with it and the 6lb lower.
Old Jun 24, 2003 | 08:14 PM
tommylightning's Avatar
Sounds like you need a 3.0" or the 2.9". As far as the belt, I would use the Gaterback 4080685 belt. We have both in stock, they will be on the site tomorrow.
Old Jun 24, 2003 | 09:10 PM
I think I'm using a 68" belt the 3.5" upper and 8.9"(6lb)lower. I do have the stop knocked off of the tensioner.
Old Jun 24, 2003 | 09:13 PM
alphadoggy's Avatar
You guys rock! Thanks.
Old Jun 24, 2003 | 09:29 PM
Don's Bolt's Avatar
Originally posted by tommylightning
I have the 2.7, 3.0 and the 3.2 in stock with more on the way.
You KB guys have me to thank, I sent Jim my 3" KB pulley so he could get the bore size right.
Yes the KB pulleys are now available.
Old Jun 24, 2003 | 10:24 PM
Thanks.
