Do I need clunk washers for this?
Old Jun 23, 2003 | 02:53 AM
00 SVT TOY's Avatar
Question Do I need clunk washers for this?
I was changing my oil under my truck and looked over at my passenger front tire and the inside tread block is completely smoothed off. I had an alignment done to my truck about the middle of last year for the front tires flairing on the outsides, and now this only about 2000 miles later. I just ordered 2 F1's from the Tire Rack and I know i will need at least another alignment to fix this, but do I also need clunk washers? I don't have the clunk but i think i read that they were needed to fix this as well, but i just want to make sure before i spend the money.
Thanx,
Bill
Old Jun 23, 2003 | 09:21 AM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
yes
Old Jun 23, 2003 | 07:19 PM
00 SVT TOY's Avatar
Thanx, I guess I will order some asap.
Bill
Old Jun 23, 2003 | 08:32 PM
cyntaxx's Avatar
Remember to install the clunk washers AFTER the alignment.
Sir Speedy: Is it true the clunk washers do not allow adjustment of caster after installed?
Old Jun 23, 2003 | 09:30 PM
Question egads
NO NO NO
If you install them after, the alignment for which you just paid is money wasted.
Easy install..
Buy washers and cam bolts
Install washers and bolts
grease steering stops
Take to alignment shop with these specs:
Lightning specs (Ford):
L.H. Caster: 6.9, +/- 1.0 Deg.
R.H. Caster: 7.4, +/- 1.0 Deg.
L.H. Camber: -0.5, +/- 0.7 Deg.
R.H. Camber: -0.5, +/- 0.7 Deg.
L.H. Toe: -0.05, +/- 0.15
R.H. Toe: -0.05, +/- 0.15
Lightning Owner preferred:
LH Caster 6.7
RH Caster 7.2
LH Camber -0.5
RH Camber -0.5
LH Toe -0.05 (slight toe in)
RH Toe -0.05 (same)
Enjoy freedom from clunkdom, or something.
Bob
Old Jun 23, 2003 | 09:49 PM
00 SVT TOY's Avatar
I have to buy cam bolts also ??? I thought I only had to buy the washers, bearing in mind I do not have the clunk. Let me know.
Thanx,
Bill
Old Jun 24, 2003 | 03:46 PM
DHFerguson's Avatar
I can't find the thread (with pictures) on the cam bolt install. My washer install pictures are at the end of this thread:
https://www.f150online.com/forums/sh...&postid=575595
Old Jun 24, 2003 | 04:28 PM
captainoblivious's Avatar
Thanx,
Bill
Every Lightning has the potential for the clunk, it just may not have happened yet.
How it goes is the slot on the lower a-arm is part of the factory alignment, and the upper a-arms are both in a fixed position. Installing the slotted washer in the lower a-arm messes up the alignment. And with both lower and upper a-arms all now being in a fixed position you cannot re-align the vehicle. So the cam bolt kits are needed to replace the fixed bolts on the upper a-arms to allow for an aligment.
Old Jun 24, 2003 | 09:10 PM
00 SVT TOY's Avatar
Do i get the cam bolts from Ford or does somebody on here make them as well? Also, if i go to Ford with the TSB # are they going to fix all of this stuff or am i better off doing this all myself?
Thanx,
Bill
