who makes the BEST (no oil in the intake) Mod
I just replaced my intercooler and the stock one was coated in oil after 9000 miles.
WHICH COMPANY MAKES THE BEST, KEEP THE OIL OUT OF MY INTAKE, MOD?
WHO DO I CONTACT TO GET IT?
(whoops, damn caps locks)
WHERE does the oil go with the REM mod, when it leaves the valve cover?
http://www.razorsedgemotorsports.com...products_id=82
is that what you are taling about?
I think K&N makes the best no oil or crankcase gas in the intake mod. Stick a K&N breather on each side on the valve cover. Block the lines and you're set. No more crankcase gases to screw up the IAC and no more oil in the intake.
I have an oil seperator on the pcv line and also an oil breather on each valve cover, I no longer get any oil in the intake at all, you do need to remove the oil breathers every so often to clean them, but it works, I also dyno`d with this set up and the air fuel ratio was perfect.
Larry.
Larry.
