what times should be expected???
Old Jun 21, 2003 | 05:05 PM
gm killr's Avatar
almost finished putting on the NX system. just wondering what times I should expect to see with these mods and a 50 to 75 shot.
2400 stall convertor
longtubes
3 in siamese exhaust
6lb lower
2.7 upper
e-fan and cobra water pump
billetflow single blade t/b
jlp air induction
jdm bigger heat exchanger
jlp traction bars
hoosier slicks
jdm flip chip
any input would be appreciated.
Old Jun 21, 2003 | 05:10 PM
cyntaxx's Avatar
11.85?
Old Jun 21, 2003 | 05:13 PM
Spanky99L's Avatar
25.2 @ 14.65mph
i don't think you will finish the run unless you are built.
Old Jun 21, 2003 | 07:01 PM
LatemodelRacer2's Avatar
Im with spank on this one. Enjoy the firs couple runs till she blows
Old Jun 21, 2003 | 07:07 PM
NJLightning01's Avatar
I'm with Spanky on this one. If you do have the opportunity, you have to make the best of it, cause I don't see it lasting. I also hope you have a loop, in case your D/S doesnt survive...
Old Jun 21, 2003 | 09:29 PM
Rob_02Lightning's Avatar
6lbs or More is pressing it
Although I've made (3) Nitrous passes using 6lbs of Pulley and 75 HP Jets, I WOULD NOT SUGGEST IT on a stock Motor.
Besides,
my best Juice ET's are still with 4lbs of Pulley and 65 HP Jets
With 4lbs of pulley you should easily be in the 11.6- 11.8 range
If i can run (2) 12.0's with stock exhuast, tranny, convertor, fans, pump, no cooler, etc... Then you should be MUCH FASTER
Start with 4lbs of pulley and see where you are.
Plenty of us are doing that.
BUT BE CAREFUL
AND MAKE SURE YOUR LIMITER IS WAY UP THERE @5700.
If you hit the Fuel shut off while spraying, IT WILL GO BOOM
Old Jun 21, 2003 | 09:31 PM
Scott Dunn's Avatar
Re: what times should be expected???
longtubes
6lb lower
2.7 upper
jlp air induction
jlp traction bars
hoosier slicks
jdm flip chip
uhh....BOOM!!!...good luck!
Old Jun 21, 2003 | 09:42 PM
fast1's Avatar
Hammer down
Get ready to run 11's
Old Jun 22, 2003 | 12:17 AM
Vinny's Avatar
Man that seems a little much for a stock block. More power to ya though. If you blow it up, you get a better one...
Vinny
Old Jun 22, 2003 | 12:22 AM
blown318's Avatar
I think you forgot the "towtruck mod" for the ride home!!!!
