How can I get the Service Engine light off?
Like I said, it's been on ever sence I put on the pro m 80mm mas air. I had to cut and extend the sensor that goes into the end of the filter so it would fit the new filter. After that, the SES light has been on. I've had the truck read once at the dealer and it was said to be reset. 1 code that came back, was too much boost for the blower. We thought that was a cool one. but now I have a 90mm on, but the wires are still spliced. How do I get it back to normal, and get the ses light off? Thanks, Shane
whenever my ses light come one i whip out the auto tap and check the problem...fix it if necessary, then clear the codes. try and find a friend or repair shop that has auto tap or something similar.
Jeff had one at us41 last time I was there. Just plug it in and have it read. It will then let me know the problem? I think I know what it is. I was wondering if anyone else with the pro M had to rewire the sensor and their ses light came on?
The dealership said they reset it and it should stay off. and that lasted a few hours! what else can it be?
any more advise to getten that ses light off, I'd appreciate it. thanks, Shane
You have to fix the cause of the codde to keep the light off
Originally posted by Crued
Where in IL are you? If yer local to the ohare area, I can scan the code and remove it for you.
