JLP Thunder Pipes....
Jlp Thunder Pipes....
We @ JLP Are Now offering our NEW Thunder Pipes $ 159.00. This TP is a perfect fit for our Airkits and also for those who use other types of A/Kits.......JL
I need that too,
Dam Johnny, this is like me waiting for the wish book at xmas time when I was a kid, AND FINALLY IT CAME
All this new stuff,
and all at the same time
All this new stuff,
Originally posted by cobra97snake
so are those things only good for appearance? they really dont do anything performance wise right?
I don't know if someone brought it up earlier yet, but it sure looks like a modified Cobra one (not that there is anything wrong with that)...
Like someone else asked earlier, is it paintable? Or will you offer more colors? And most importantly, it works with other open-element type filter designs correct? No shaving required like the REM tubes?
Originally posted by easterisland
Is it available with only one hole on the bottom for the IAC tube? I don't need the line going to boost bypass actuator or the line going to valve cover.
Originally posted by DL
Put a plug in it easter, you can't see it..
It should be cheaper and easier to make if there is just one hole on the bottom. I know some people like a couple holes. I can only use one at a time though.
I'm sure JL wishes it was that simple to change the mold. He would have to make a new mold without the holes Easter for only a few people. I don't think JL wants to pay the additional cost of fabricating a new mold for just a few customers...
I think it's possible for easter to get a smooth intake tube with one hole.
The REM ones are molded with no holes in them and then Paul uses a unibit and a drill to make the three holes. It would be extremely easy just to drill one hole and supply the proper grommet for it instead of doing all three. I can't speak for JL if his manufacturing method is the same, but if it is then a single holed one would be an easy thing to do.
