JLP Thunder Pipes....
Old Jun 12, 2003 | 06:50 PM
Odin's Wrath's Avatar
What's the minimum interior diameter? What are the batteries for?
Old Jun 12, 2003 | 08:14 PM
DL's Avatar
DL
Originally posted by MISTERgadget
I think it's possible for easter to get a smooth intake tube with one hole.
The REM ones are molded with no holes in them and then Paul uses a unibit and a drill to make the three holes. It would be extremely easy just to drill one hole and supply the proper grommet for it instead of doing all three. I can't speak for JL if his manufacturing method is the same, but if it is then a single holed one would be an easy thing to do.
Hmmm, didn't know that...There you go Easter, another option..
Old Jun 12, 2003 | 09:20 PM
todd abbott's Avatar
The pipe looks great John, I guess my questions are the same as everyone else, is it metal or composite is it sprayed or powder coated, color options ( black is just fine with me ) for a 160.00 it's worth it just to clean up under the hood and it bolts right up to my ram air. I think a call to Sue is in order.
Old Jun 12, 2003 | 10:20 PM
C BROWN's Avatar
Originally posted by cyntaxx
Hmmm...I've thought about polishing my rubber boot instead.
Why polish it; I'm gonna get mine chromed
Old Jun 12, 2003 | 10:32 PM
JohnnyLightning's Avatar
The Pipe is made of a fiberglass material. it is paintable with no problems. As far as adding additional power, I don't expect no Huge gains maybe around 25 HP! NOT! Its mainly Cosmetic to dress up the engine bay...
Easter: sorry it has 2 holes plus the small one. it comes with gromments that you could plug if you need to...JL
