Who has the best 60ft. w/stock torque converter?
Originally posted by bad00
wow, good mph,i just cant seem to get a good 60' or any mph for all the work i have done. it might just be time to take it to another tunner!!!
A stock lightning makes anough torque to get decent 60 foot times with a good driver and a good track
The MPH isa diff problem all together
Doug
"The MPH isa diff problem all together"
yea i knowmy mph is only 103-104. I bring it up on the converter to about 2300 and let it rip...when you guys are pullin these good 60' times your NOT SPINING AT ALL right? OH and my truck is a 00 w/3.55's
If you have a stock convertor try leaving at 900 rpms or so.........and report back to us
--Joe
This is what i have done to the truck,2lb upper pulley,4lb lower,full jdm ss exhaust w/longtubes,cone filter, 90mm mass air,boost by pass,breather cap,denso IT 24's,custom built 4r100, PI 2600stall,cal-tracks,26-11.5-16 ET streets,2"rear drop shakles, diablo sport chip tuned for 104octane,a/f is 11.8 on the wideban,hitch is gone, front sway bar gone, 4858lb w/me in it.
Man thats slow for what you got done. We have pretty much the same mods almost.
first off those It 24's are to cold for what your doing. It22's at most. I run Tr6's most of the time and then BR7's when i want the juice on. Even if you where spinning off the line your just going to MPH more in the long run. I have zero traction issues with my truck and it just hooks and goes no problem. Maybe the track your going to have *****ty prep and maybe your just not lowering the pressure on your slicks enough or your not heating them up enough.
Take those E.T. streets down to about 12 psi before you do your burnout, then they will be around 14 to 15 psi when your ready. Heat them up really good too, do a burnout up to about 80mph or so for a good 5 seconds atleast. then just get your RPM's up and take off like a bat out of hell.
yup
I'm not calling you a liar, but I just have a very hard time believing that a 1.63 was cut on F1's. Were you already rolling or something?
Yup, this is true.....many witnesses to it too. Couldnt believe it myself. Don also pulled a 1.71 60 I believe on f1's on his truck making a 12.0 pass. The guy can drive, unlike me.....hehe.
Re: yup
Seriously...at what track was this at because I want to go there. E-town sucks for traction most of the time and sucks for the attitudes of the people working there all of the time.
Re: yup
unless u guys do sumthin to your track that noone knows about...
I am always at e-town or atco NJ. So you think my MPH is down cause the tires are spining one or two rotations? Dont get me wrong, it spins for a spilt secound then leaves hard,but I still get I get low 1.8's.
