2lb GatorBack #, 4080??
Old Jun 9, 2003 | 04:12 PM
TampaBlack99's Avatar
(2 Lber) = 4080??? GatorBack
Do people use the stock belt for a 2lb pulley?
Old Jun 9, 2003 | 04:13 PM
cyntaxx's Avatar
Think you can use your stock belt length...
or a 66 incher...
Old Jun 9, 2003 | 04:28 PM
soap's Avatar
4080660 = 66" Gatorback belt.
GDTEY HYWS
--Joe
Old Jun 9, 2003 | 04:39 PM
So it's the same size as a stock belt?
Old Jun 9, 2003 | 04:47 PM
cyntaxx's Avatar
I believe so.
Old Jun 9, 2003 | 05:00 PM
Old Jun 9, 2003 | 05:11 PM
SpankDog's Avatar
Banned
since i put it my FTVB my belt squeals like schitt on the 2-3 shift, any ideas?
Old Jun 9, 2003 | 05:12 PM
MISTERgadget's Avatar
stay in 2nd gear the squeal shouldnt show up again.
Old Jun 9, 2003 | 05:16 PM
jeff2001silver's Avatar
I used the stock belt with a 2 lb lower. It was tight and a b!tch to get on, but once on never had any issues.
Old Jun 9, 2003 | 05:22 PM
cyntaxx's Avatar
With the stock belt or a GY GB? You should see no squeal with a GY GB (66 inch) with a stock pulley, etc...
Old Jun 9, 2003 | 05:27 PM
SpankDog's Avatar
Banned
GY GB....on my stock upper and my JL 5# lower, i was thinking it might be the accessory belt......
Old Jun 9, 2003 | 05:29 PM
cyntaxx's Avatar
Whoops I read your sig wrong and thought u had no chip/pulley.
With a 5# I would go with a 67.5 inch or 68. I dont know if they make anything in between those two. My 67.5 incher fits snugly with my 4#.
Old Jun 9, 2003 | 05:30 PM
SpankDog's Avatar
Banned
I'll have to figure out what belt # i have......when i get home
Old Jun 13, 2003 | 01:20 AM
lxtac's Avatar
4080670 = 2# lower!
I have a 2# lower and the stock belt simply would not fit. I've been working on cars all my life so it’s not a skill issue, the belt was just a hair to short.
I just got a 4080670 and it fits perfect!
Btw for long term use an engineer told me a belt that is to tight will causes excessive ware for bearings on front engine assy. parts.
You should make sure your tension indicator is within the "range" printed on it.
With the 2# & 4080670 mine points just above the middle. This is a perfect fit.
Johnie
Old Jun 13, 2003 | 05:36 AM
Marc Carpenter's Avatar
Interesting, as I run a 4080665 with a 6# lower.
