Intercoolers???? spearco or stock?
Old Jun 2, 2003 | 10:56 AM
RTKILLA's Avatar
so does anyone have any new info on the spearco intercoolers coming out?
are they going to be worth it or should I just get a new stock one now?
How much are the stock ones running and where can I get one at cheap.
Old Jun 2, 2003 | 11:03 AM
clonetek's Avatar
i'm surprised you didn't take it back for the recall... :o
Old Jun 2, 2003 | 11:07 AM
Flying Mofo's Avatar
Banned
The prototype done out here did absolutely squat for performance and there was no projected price either.
Old Jun 2, 2003 | 11:51 AM
RTKILLA's Avatar
brooks I did, its leaking again!
so screw the spearco then huh, stock it is.
thanks ****.
Old Jun 2, 2003 | 11:58 AM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
FYI..
If you had the correct recall done, you should already have the 01 setup.
Old Jun 2, 2003 | 12:02 PM
RTKILLA's Avatar
Re: FYI..
well then its a 01 setup leaking.
By the way, speedy check your TRQ wrench cause I have to use like 100 foot lbs of pressure to take those bolts off for the tranny pan.
Old Jun 2, 2003 | 12:05 PM
soap's Avatar
Re: Re: FYI..
Heat cycling tends to make bolts harder to remove
--Joe
Old Jun 2, 2003 | 12:14 PM
RTKILLA's Avatar
I think speedy has been working out or somthing.
Old Jun 2, 2003 | 12:23 PM
soap's Avatar
12 oz curls do improve arm strength like none other
--Joe
Old Jun 2, 2003 | 12:24 PM
RTKILLA's Avatar
--Joe
HELL YEAH!
