problem w/right side engine
Old May 31, 2003 | 11:21 PM
ub2slo's Avatar
Unhappy problem w/right side engine
When I changed my shorty headers to LT's I noticed the driver's side header had an extreme amount of carbon build up, while the passenger side hade little to none at all. Also, the last two times I went to dispose the oil I changed the mechanic told me that It looked pretty bad and that I should use some engine cleaning additive before my next change. What could be causing this? And what should I do to get my engine running good again? Maybe a good chip tune? Below are my mods.
JDM cold air intake
ASP 4# pulley
Full Bassani
Old May 31, 2003 | 11:47 PM
Nathan's Avatar
do you have a valve cover breather?
Old Jun 1, 2003 | 12:22 AM
Flying Mofo's Avatar
Banned
Could it be that your right side cylinder head is leaking?
Check the back side of the head.
Old Jun 1, 2003 | 09:00 AM
LIGHTNINROD's Avatar
Plugs too 'cold'........???
Leaky valve seals.....???
Dan
Old Jun 1, 2003 | 10:36 AM
ub2slo's Avatar
Dan
Sorry for asking but how do I check for a leaky valve seal, or a leaking cylinder head?
Old Jun 1, 2003 | 07:07 PM
You won't be able to do it. A tech will have to run some tests.....
Dan
