Why so slow
Old May 30, 2003 | 11:55 PM
whtlight01's Avatar
Unhappy Why so slow
Went to the track tonight after installing JDM bars so I could finally run my Bogarts. First off the place was over crouded took forever to ge a run in and when I finally did I would hav rather been home watching tv. heres the times.
FIRST RUN
1.969 60
8.249 1/8
12.850 1/4
106.90 mph
SECOND PASS
1.916 60
8.310 1/8
12.984
14.96 mph
Ok so what the @!$#@! is up!! I didnt heat the tires up to good first pass...second I thought I did but I guess not. anyway heres the mods. 6# metco lower...CAI...JDM chip NGK TR6 gap 40 ...Boost bypass..e fan...R pump...FT VB..loop...bars...rear bogarts Hopefully someone can help...Tuck went best of 12.7 @109 last year Only new mod is slicks and the VB Going to have it Dynoed monday hopefully. Any ideas?
Old May 30, 2003 | 11:57 PM
cyntaxx's Avatar
Is it stumbling down the track at all or does it feel like it's pulling strong throughout the runs? Also, I assume you're running DRs or slicks with those Bogarts so those 60' times leave something to be desired...
Old May 30, 2003 | 11:59 PM
LightningTuner's Avatar
Well, your mph seems down from your previous times, BUT, your 60fts are horrible too. You said you are using new wheels, if the tires were also new, then using them for the first time brings out all the oils and such. If this was the first time using them, they should work better next time out.
Old May 31, 2003 | 12:02 AM
whtlight01's Avatar
It seeed to pull good seems like it was spinning through the tires though. Im running ET streets at 17 psi the have 7 pass's on them tonigh was the firt time I used them though. Too me it seems like my mPH sucks witch tells me the truck isnt making much power. also the temp was 63 with humidity at 73
Old May 31, 2003 | 12:09 AM
cyntaxx's Avatar
How are you doing the burnouts? Heating them up good? How are you launching? Holding RPMs at xxxx?
Old May 31, 2003 | 12:18 AM
whtlight01's Avatar
I sat on it the first time too short but the second time I sat on them for awhile till I saw a lot of smoke. I left off the convertor, but felt like it still spun a little.
Old May 31, 2003 | 01:28 AM
VINNIE's Avatar
That is why I went to cruise night tonight instead of Racing. I figured and the tracks are VERY green with all the rain.
I definately would not put that much into tonight. Go back one more time (under better conditions) and see what happens, then call Jim, so you can give him the most info possible for the best tune.
Or better yet . Go to JDMs for the dyno.
VINNIE
Old May 31, 2003 | 08:58 AM
trashguy's Avatar
vin
where did you go somerville?
i was at the cruise in jackson last night
holy cow is there alot of cars there
