Lakewood Traction Bar part #???
Anyone running them know if this is the right part #: 620-21715. Jeg's lists them as heavy duty for up to a '99 F150. If not, what's the right # and where did you get yours?
Any info is appreciated.
No flames or pi$$ing matches needed.
Thanks,
Dan
Thanks,
Dan
That is the ones I put on my 01 and thay work great. $90 delevered makes them even better. You may need a few extra washers or spacers to set the gap on the snubber. I run mine at 3/8" but I do not carry much in the bed. If you do haul stuff from time to time you may want a larger gap beacouse it may get a little bouncey with a load if you don't. If you rotate the clamp on the stock exaust you can get them to contact just before the spring eye.
Dan
