Spark Plug torqued to
Old May 30, 2003 | 08:32 PM
billarf's Avatar
Spark Plug torqued to what on an '03 L ? Thanks in advance for the info!
Old May 30, 2003 | 08:52 PM
soap's Avatar
Re: Spark Plug torqued to
According to Ford manual:
Torque spec = tight plus 1/8 turn
--Joe
Old May 30, 2003 | 09:29 PM
SpankDog's Avatar
Banned
I thought it was 1/16th?
Old May 30, 2003 | 09:48 PM
billarf's Avatar
Re: Re: Spark Plug torqued to
--Joe
Just to double check.... on an 2003 Lightning, Spark Plugs are torqued to what?
Old May 30, 2003 | 09:51 PM
soap's Avatar
Re: Re: Re: Spark Plug torqued to
Another words.........you will never get a proper torque on the plugs because of the swivels involved in the job. So tighten them up snug then an 1/8 turn more.........or 1/16th.......whatever it's Friday
--Joe
Old May 30, 2003 | 10:38 PM
Dan SS2471's Avatar
What Soap is trying to say is that there aint no torque spec. Get them snug then tighten them as much as you can with the mouse-trap derived combo of ratchets, sockets, extensions, adapters, swivels. That's not exactly a text book answer but it's about what you're gonna hear based on past experience.
Old May 30, 2003 | 10:51 PM
Thor01's Avatar
billarf,
All nuts, bolts and plugs on Ford modular engines have a torque number.
Plugs are 16-20Nm.
Torque Value for fastners on 5.4L Lightning.
Note:
Prior to service re-installation or replacement of fastners, all threads and contact surfaces must be lubricated with
WSE-M2C908-A OR WSS-M2C914-A OIL.
THREAD SIZE-----------------------TORQUE
M6 X 1 ------------------------------8 - 12 Nm.
M8X 1.25 ------------------------- 20 - 30 Nm.
M10 X 1.5 ------------------------ 40 - 55 Nm.
M12 X 1.75 ---------------------- 70 - 95 Nm.
M14 X 2 ----------------------- 110 - 155 Nm.
1/8 - 27 PIPE --------------------- 7 - 11 Nm.
1/4 - 18 PIPE -------------------- 11 - 16 Nm.
3/8 - 18 PIPE -------------------- 16 - 24 Nm.
Note:
Pipe plug torques in aluminum must be checked when engine is warm.
THOR
Old May 30, 2003 | 10:53 PM
I8ACAMRO's Avatar
spark plug torque: 11 foot pounds, or 132 inch pounds.
Old May 31, 2003 | 01:33 AM
Grimace's Avatar
So, exactly where are the damn plugs anyway? I looked for them, but coudn't see chit. Also, why are people changing the plugs already on an 03? Aren't they 100,000 mile plugs?
Old May 31, 2003 | 01:38 AM
SpankDog's Avatar
Banned
The plugs are under the green coil packs
See the plug down there?
We change plugs when we do mods.
Old May 31, 2003 | 08:34 AM
SVT F15O's Avatar
Woah! 11FT LBS sounds like a disaster waiting to happen. From what I have been told by a tuner and from past experience that is waaaaay too low. -Mat-
Old May 31, 2003 | 08:47 AM
billarf's Avatar
No, I will not be changing plugs real soon as I only have 1400 mi. on my '03 L. I do plan on checking plugs for tightness every few thousand miles though.
Old May 31, 2003 | 10:06 AM
LIGHTNINROD's Avatar
Scroll ALL the way to the bottom of this http://www.densoiridium.com/installationguide.htm page for the correct(IMHO--and Denso's) plug tightening method.
DON'T tighten them too much. The 'soft', aluminum threads(in the heads) will weaken and release the plug sooner or later. I ran mine down finger-tight(with the socket, of course) and then 1/16th of a turn more! and my NGK BR7EFs have been in for about 29,000 miles.
Dan
