extruded upper plenums???
Old May 31, 2003 | 12:34 PM
Odin's Wrath's Avatar
Re: Good Info Struck in AZ
Originally posted by BufordTJustice
P.S. Odin's Wrath, what happened to your AFM Power Pipe? Myself and ThunderStruck are still running ours. I have gotten a 12.01 out of it and ThunderStruck nailed an 11.92 with his.
Nothing wrong with the Power Pipe, I just prefer the enclosed system offered with the Volant. They've made the improvements needed to eliminate the restriction problems of the previous design.
Old May 31, 2003 | 01:13 PM
easterisland's Avatar
My EXTRUDE HONE intake flowed 965 cfm in 28" water. Stock the same upper intake flowed 850 cfm in 28" water. Worth $150. Much more so than a $500 shiny TB, that's for sure. Hope this helps.
What does the extrude hone piece flow with a stock throttle body as compared to an oval bore throttle body? I basically just want to know if a stock throttle body flows 965 cfm.
Old May 31, 2003 | 01:56 PM
BufordTJustice's Avatar
Re: Re: Good Info Struck in AZ
No data on that combo. I was quoting the upper intake only. I believe if you search there was data comparing throttle bodies and both Ba-Bolt and Accufab were comparable in flow rates. I could be mistaken but my memory ain't what it used to be. Regardless, the glass smooth result of EXTRUDE HONE can only help the higher boosted applications. Stock trucks will probably see none to negligible gains. Hope this helps.
BTJ
Old May 31, 2003 | 02:03 PM
wkuper11's Avatar
wouldnt the hand ported plenums be better? the extruded ones i've seen still have the "petrusions" on the inside. I hand ported mine and grinded them down, and the ones from REM look good too.
Old May 31, 2003 | 02:15 PM
Thumbs up BTJ combination
I hand ported the "obstructions" before the EXTRUDE HONE process.
BTJ
Old May 31, 2003 | 03:08 PM
No.
Old May 31, 2003 | 03:21 PM
todd abbott's Avatar
I've been wondering about actaul gains with this done, can someone point me in the right direction, are you buying a new upper intake then sending it out or are pulling the existing and putting the truck down for a couple of weeks. Thanks, Todd
Old May 31, 2003 | 09:08 PM
Struck in AZ's Avatar
Ahhh...Buford my good man, I don't doubt that were talking SAE corrected on both runs but I've seen runs vary by as much as 10 hp (SAE corrected) depending upon the weather conditions. In fact, if I try to compare one of my runs made in 95-degree heat to a run made in 50-degree winter weather the Dynojet software will warn me that the weather conditions between the two runs are significantly different. I don't doubt that it helped...and if you get a 10th out of it it appears that it did...I just don't think everyone will see the 10-15 and 20-25 that some people claim.
Dan
Old May 31, 2003 | 10:17 PM
Mondo1's Avatar
Originally posted by Odin's Wrath
No.
Actually they are when they are polished after they are ported. Ever see one that Next generation Motosports has done? It actually comes out smoother than the extrude honed one. I know cuz I had both. No "nooks or crannies" like occurs with the extrude media process.And they basically dyno the same . We got 6 h.p. and 15 ft. lbs of tq. on an Eddy Current Mustang dyno which is more conservative than the dyno-jets.I am more than pleased with mine.
Old May 31, 2003 | 10:45 PM
Depends on time and effort. Only trust yourself, or someone who has already shown themself to reliable, if porting and polishing is your choice. With the air being forcefully drawn through the plenum by the blower, the amount of material removed is more important than the smoothness of surface the air passes over. Extrude Hone not only removes more material, it's more repeatable and isn't subject to the motivation of the person doing a hand porting job. Of course, that's just my experience.
Old Jun 1, 2003 | 02:10 AM
Mondo1's Avatar
True...but these are done with "love" And the turn around time is intantaneous.With my first extrude hone , I had to wait over 2 weeks to get one.
