Help: best shocks for Hotchkiss?
Old May 29, 2003 | 04:54 PM
meiwah98's Avatar
Need recommendations for my '01L.
I have Hotchkiss now, called Hotchkiss and they still abide by their recommendation of staying with factory shocks.
My L is my daily driver, street and highway only. I am still bouncing up and down, more that I would like. I have done the search and have heard nothing bad about QA1's adjustable shocks. However, they are expensive.
Any alternatives before diving into QA1's? Appreciate anyone who has tried Edelbrock or Bilstiens with Hotchkiss.
Old May 29, 2003 | 04:59 PM
Don's Bolt's Avatar
E-mail stan ruslow and get a set of his QA1's
Old May 29, 2003 | 10:21 PM
Tim Skelton's Avatar
Re: Help: best shocks for Hotchkiss?
Originally posted by meiwah98
. . . I have Hotchkiss now, called Hotchkiss and they still abide by their recommendation of staying with factory shocks. . .
Makes me very suspect of the engineering which Hotchkis put into their kit. The stock Bilsteins are clearly no good for their springs. I speak from experience.
Old May 29, 2003 | 10:25 PM
cyntaxx's Avatar
From what I've heard, QA1s go great with the Hotchkis leafs
Old May 29, 2003 | 11:21 PM
Ayrton's Avatar
QA1 or Penske...
Old May 30, 2003 | 12:39 AM
alphadoggy's Avatar
And make sure that you mount them with Ruslow's heim joint kit, otherwise they will bind and break.
Old May 30, 2003 | 03:25 AM
JewishLightning's Avatar
QA1 QA1 QA1 QA1 QA1 QA1 QA1
I think you can buy them from summite for 140 a pop
Old May 30, 2003 | 01:39 PM
meiwah98's Avatar
Alphadoggy: what is this item?
Sorry, I'm a newbie at suspensions so I don't know what this kit does. Can you clarify? I'll ask Ruslow when he emails me back about the QA1's.
Thanks.
Old May 30, 2003 | 02:22 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
heim joint
meiwah,
The heim joint and mount bolt to your shock mount thereby all but eliminating binding on the shock shaft. pictured in lower left hand corner of the below image.
Old May 30, 2003 | 03:15 PM
Silver-Bolt's Avatar
Will someone post the QA-1 P/N's for the front and rear?
Old May 30, 2003 | 05:24 PM
suds5.4's Avatar
Here are the part numbers for the direct replacements. They may not be the correct ones to be used with the heim joint option.
The front shocks are part number TC-1538-P (2)
The rear shocks are part number TC-1610-P (2)
T-bar conversion kit is part number LWR300 (2)
T-bar bushing is part number 9032-102 (2)
Old May 30, 2003 | 05:48 PM
Thanks Suds.
Old May 30, 2003 | 09:02 PM
meiwah98's Avatar
Thumbs up
Thanks Alphadoggy; I confirm with Ruslow when I contact him about the shocks.
Old May 30, 2003 | 10:28 PM
Ayrton's Avatar
FYI
QA1 offers two different rear shock options depending on your drop, so be sure to measure from mount to mount before ordering.
Old May 31, 2003 | 06:42 AM
If your truck is lowered you have to use the QA1-MU7855P rear shock. I'm doing my homework on my suspension upgrade so I'm going all out real soon.
