getting Roush suspension, have a few ????
I'll be ordering my Roush kit tomorrow but wanted to know a few things I couldn't get direct answers through searching previous posts. As far as bumpstops are concerned what should I do? And how about the endlinks? Has anyone purchased the kit w/out the shocks, I read where the shocks are the same length as stock and probably won't make much difference.
I think the kit includes front bump stops. I used the bumpstops from a 99 on my 2001, but if you have a 2001 or newer you can just cut them down. I don't know if the shocks are different, but I used the Roush shocks.
I've heard that it is recommended to use the custom-valved Roush shocks because of the higher rate leafs. However, I don't think it will be too bad on 01+ Bilsteins...
As for the bumpstops, why didn't you use the ones provided by Roush Easter? Any particular reason? I have an 02 and am thinking about this kit. I know with coils that drop your front above one inch, some shave off their stock bumpstops...
ub2slo
You will get front bumpstops with the kit. I trimmed about an inch off of my factory rear bumpstops.
I left the enlinks stock for now but I hear that people are using Energy Suspension front end links and cutting a couple of inches off of the rears.
I purchased the kit with the shocks since my 00 didn't come from the factory with the Bilsteins.
Good luck with the install
Laurence
Laurence
Originally posted by Tim Skelton
You can also just use the stock front bump stops on the rear.
i was told by roush that the shocks are different. they are the same length but the valving is different. I also used the stock front bump stops and put them in the rear. no cutting involved. like svt ky stated you just need two new bolts and two new nuts.:: beers
