Wheel/Slick ?'s
Old May 20, 2003 | 11:00 PM
C BROWN's Avatar
Wheel/Slick ?'s
I am finally getting around to buying some wheels/slicks; I am busy doing research on the two. Here are my questions;
I see M/T has a 28x11.5-16, but the tread only shows 8.7 then they have a 28x12.5-16 that has a 10" tread. I also looked at some 27x10.5-16 which had 8.9" tread(the 27 would help my gearing on an 02) I then looked at Hoosier who has 28x11.5-16 which's tread is 10". Basically which would you guys suggest I get? I want "DOT" tires, and am planning for some mid to low 12's in an 02 L.
Then on wheels, all I looked at was 16x10's. Eagle Alloy has some that weight 25 pounds, M/T has some that weight 22 pounds, and American Racing Baja has some, but published weight. I am kindof leaning toward the M/T's since they were in the $120 range. Sorry, Bogarts are a little to much $$$
Also, will 4 1/2 back spacing work/look right on the L. And should I plan to get tubes, or can I run them tubeless(prefered for me)
Old May 20, 2003 | 11:04 PM
Justin@JDM's Avatar
Banned
Save yourself the trial and error and just go for the Hoosiers with the Baja wheels. We sell them already mounted and balanced.
Hope this helps,
Justin@JDM
Old May 20, 2003 | 11:22 PM
C BROWN's Avatar
Whats the $$$'s
Old May 21, 2003 | 01:09 AM
cyntaxx's Avatar
120 brand new for an ET Street? Where? I was told they were around 170-180/piece.
Old May 21, 2003 | 06:28 AM
Justin@JDM's Avatar
Banned
$770.00 mounted and balanced.
