Quick question about placement of flip chip toggle switch...
Old May 19, 2003 | 06:09 PM
Rob_02Lightning's Avatar
Like Doug says
The perfect spot is already there, has the holes pre drilled, and it's ready to be used with no drilling or hassels
Old May 19, 2003 | 06:14 PM
ShaneMcKenna203's Avatar
and Rob, i can take it in and out of there if I need a reburn?
Old May 19, 2003 | 06:27 PM
Shane
The switch stays in for good once it's in.
When you take the chip out, you simply un-plug the wire to the switch and that all stays right there while you send your chip off for a re-burn.
Mines out for a reburn right now. Lets see this is my 9th and 10th program in @ 6 months now. I have my old spare single chip in for now and the switch is just sitting there not being used til I get the Delta Chip back, then plug the wire back in to the chip, push the chip back in the computer, AND YOUR GOOD TO GO
Old May 19, 2003 | 06:29 PM
Unless yours is differant than a Diablo Delta Mulit Program Chip,
THATS HOW MINE WORKS ???
thanks rob, i didnt know you could disconnect the wire/toggle from the chip.... if you can do that, im fine. I can mount it anywhere. thanks, Shane
Old May 19, 2003 | 06:32 PM
the dual program chip I'm talking about is a Superchip. I do currently have a single program diablo. Once I get my superchip back from getting a reburn I will try that... thats the chip and toggle switch I need to mount...
