Help with Chip Problem [Merged]
Old May 11, 2003 | 02:14 PM
Sonic03's Avatar
Help!!!!!!!
Just installed chip and left the keys in the ignition. Now when I try to start the truck, I get the theft light flashing at me. What do I do? I need some help fast.
Old May 11, 2003 | 02:26 PM
blowntruck's Avatar
Crap, I am not sure but they always told that was a BIG NO NO.
Old May 11, 2003 | 02:27 PM
Sonic03's Avatar
Realize that but have you had any problems the chip.
Old May 11, 2003 | 02:30 PM
blowntruck's Avatar
I have never left the keys in the ignition.....
Old May 11, 2003 | 02:32 PM
Sonic03's Avatar
Sorry, I made a mistake the keys were not in the ignition. I am the wife of Sonic03 and want to help him to fix the problem. Any help will greatly be appreciated.
Old May 11, 2003 | 02:38 PM
Sonic03's Avatar
Just installed chip and now getting the flashing theft light. Has anyone had this problem? Can someone give me some help soon? Thanks you guys.
Old May 11, 2003 | 02:40 PM
blowntruck's Avatar
Either the chip isnt set in right,
the cpu and the harness are not all the way connected
or maybe the contacts need more cleaning
Some suggestions. Good luck
Old May 11, 2003 | 02:43 PM
blowntruck's Avatar
Pretty sure the terminals (contacts) are not clean enough yet.
Old May 11, 2003 | 02:48 PM
SVT_FL's Avatar
You need to reclean the contacts, seat the chip securely and tape it.
Old May 11, 2003 | 02:53 PM
ShadowBolt's Avatar
If your truck is an 03 and your chip is a PSP 4-way you need to call Sal. They are having a problem on the 4-way chips (I think it's only on the 03's). I cut my wires close to the chip (not too close)and it has not happened again. Sal will tell you what to do and make it right when they find out what is causing this.
Jerry
Old May 11, 2003 | 03:41 PM
Sonic03's Avatar
Thanks Blowntruck for the advice. Cleaned the circuit board 3 more times and still no good. Truck runs when the chip is turned in the "off" position, but nothing when activated. Any chance the toggle switch might be bad? My brother's '03 Cobra had a diablo chip but with no toggle switch. No problem with his. This is like the 5th one that I have done, another '01 Lightning and several Cobras. This is the first time that I have had problems, but why my truck.
Old May 11, 2003 | 03:46 PM
cpeapea's Avatar
if you still get a problem, run a search, remember about a year ago a thread about leaving the keys in the ign. and reconnecting the bat
Old May 11, 2003 | 03:53 PM
Rob_02Lightning's Avatar
Yup what SVT_FL said,
I've read of other 03's doing that.
Old May 11, 2003 | 04:10 PM
LIGHTNINROD's Avatar
Just talked to Jeff(Sonic03) and he has a Diablo with a 3-way switch. He's cleaned and installed several chips before, so I(and he) don't think it's a cleaning problem. I recommened he send it back to REM and get a hold of Tim.
Dan
Old May 11, 2003 | 04:11 PM
blowntruck's Avatar
Dang, since this is not your first time it might be the chip then. Send it back to where you got it and see what happens.
Jesse
