efan and stock pump?
Old May 11, 2003 | 02:53 AM
NateTrun2's Avatar
I was wondering if anyone is running the stock water pump with an efan? Heard you can't do it but, I think I might have read some people that have?
Old May 11, 2003 | 02:56 AM
whtlight01's Avatar
I think the twin fan set-up by flex-lite will leave enough room to use the stock pump. But I'm almost 100% sure using other fan setups you willnee to run the cobra pump due to not enough room. Plus the cobra pump is better so why not get it.
Old May 11, 2003 | 03:00 AM
NateTrun2's Avatar
Theres a loss of hp from the R pump . Guess i will have to use it.
Old May 11, 2003 | 06:02 AM
cpeapea's Avatar
you could grind the shaft off nate...not sure if thats recommended though, especially if you plan on putting it back to stock.
btw, Sat. Right?
Old May 11, 2003 | 07:43 AM
NateTrun2's Avatar
oops. i just sent you a PM. no, it's not going back to stock. I don't ever have plans of saleing it. Yeah, i say we try it and if it doesn't work then we have the R pump for back - up. I like living on the edge
Old May 11, 2003 | 08:56 AM
Road Rash's Avatar
I'm using the stock pump with an e-fan. Plenty of room.
Mike
Old May 11, 2003 | 09:37 AM
Stormyday's Avatar
I was always under the impression that the Cobra pump added HP, no?
Old May 11, 2003 | 09:56 AM
air1kdf's Avatar
The EPump adds HP
Old May 11, 2003 | 10:08 AM
easterisland's Avatar
I have heard the cobra pump results in lost HP. I am running it with a ruslow under drive pulley. Does that get me my HP back?
Old May 11, 2003 | 10:14 AM
Skank Dog's Avatar
Im running the LFP e-fan and Cobra pump, the same fan JDM sells and there isnt any room for the stock w/pump. My buddy is running the dual e-fan setup he bought from Razors Edge, and it has plenty of room for the stock pump.
I call BS on the power loss with the Cobra w/pump. If there is I sure havent noticed it. You'll gain a nice seat of the pants power increase with this swap(fan & pump)! I was really impressed how much better my Lightning accelerated! Its power you can actually feel!
The LFP fan is a plug and play set up, no splicing,cutting, soldering, or anything! And it comes with the a/c switch, manual overide in cab toggle switch for high speed, and other nice features at NO extra cost!
Old May 11, 2003 | 11:16 AM
rscoleman's Avatar
I run an e-fan with the stock w/pump. EVERY dyno sheet posted so far for the cobra pump shows a loss of power. If it flows more water, it's doing more 'work,' causing a loss of power. This is the same reason a high volume oil pump will cause a loss of power. There's no free luch with the fans, either. They put a higher load on the alternator, causing it to do more 'work.' Keep the stock pump and get an e-fan, that's the best setup.
Old May 11, 2003 | 01:28 PM
whtlight01's Avatar
It's flowing more water due to is new impellar design. This allows the coolant to be quickly moved back out unlike the stock style where the fluid gets held up and pushed unevenly riding over the impellar blades.
Old May 11, 2003 | 01:30 PM
MISTERgadget's Avatar
Just get an E-pump like cyntaxx's!
Old May 11, 2003 | 04:36 PM
NateTrun2's Avatar
I don't have the money for an epump.
Old May 11, 2003 | 05:19 PM
Ayrton's Avatar
Has anyone ever offered a explanation of why the Cobra pump is supposed to rob power?
