For those with Belltech coils
Old May 8, 2003 | 11:27 AM
93Cobra's Avatar
Where, and what part number did you order? Price?
I am looking for the front coils used in there 3/4 kit... I see some using those with drop shackles in the rear. That was my plan as I ordered the JLP adjustable rear shackles.
Thanks.
Old May 8, 2003 | 01:04 PM
TZRLightning01's Avatar
you need Belltech part # 4804 coils. this is exactly the setup I have. however I found that when I removed the hitch and the spare, the rear sits too high with just the JLP 3" shackles. I'm either going to get the 4" ones or remove a leaf from the rear springs I bought my Belltech coils off ebay, so I cant help you with where to buy from...good luck
Old May 8, 2003 | 01:57 PM
93Cobra's Avatar
Thank you. Your ride height was what I was after. I ordered the 2/3/4 shackles, so I will start at the middle hole and go from there since I do have the spare and hitch still on the truck.
Dumb question, but would the 4" drop hole be the top hole on the shackle? I can't remember which is which.
Thanks.
Old May 9, 2003 | 01:32 AM
yep, the lowest (4" drop) hole would be the top hole on the shackle...you will probably end up with the perfect stance with the shackles on this setting and the weight of the hitch and spare. be sure to post pics when you're done!
