Opinions on SoCal endlinks
Old Apr 29, 2003 | 03:29 PM
Edward's Avatar
I lowered my truck with the FRPP 1/2 kit last year. A few months ago, I swapped my front end links for some "correct" lenght ones. I definitely felt an improvement in handling. Now I'm thinking about doing the rears with the SoCal links; but I don't want to spend that much money and be disappointed. Any input?
Thanks,
Edward
Old Apr 29, 2003 | 03:45 PM
Ayrton's Avatar
Every person that has owned them has complained of the noise. Apperantly they just rattle, and rattle.
Don, and Tim both steered me away from them.
Old Apr 29, 2003 | 06:04 PM
bodawg's Avatar
As they come from So-Cal they are noisy; but, throw some Seals-it rod end seals (and some grease) on them and they are silent. Just like anything with a rod end, they will make noise unless you do something about it.
Old Apr 29, 2003 | 06:34 PM
Don's Bolt's Avatar
I took mine off and just drilled a new hole 2 inches higher in my frame rail. It does the same thing and only cost me a few bucks for a good drill bit.
Old Apr 29, 2003 | 07:05 PM
Ayrton's Avatar
Have you done this?
Should this work, then I would take a second look at the So Cal links.
Don you still have a set lying around?
Old Apr 29, 2003 | 08:50 PM
svtdvm's Avatar
Mine were greased before they were put on and I haven't heard any rattling.
Old Apr 29, 2003 | 10:29 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
owner/non-complainer
Edward,
You could build them yourself and save some $$. Shoot me an email and I'll dig up the parts list.
I'm happy with the end links and don't notice the e---vil rattle.
Sealsit product will be added to my setup just to keep dirt and tire remnant from the heim.
A couple alternatives would be to cut/weld the stockers or drill a hole in the frame relevant to the rear drop/sway bar parallel.
Bob
Old Apr 29, 2003 | 10:33 PM
Ayrton's Avatar
Bob I could use that list as well, unless Don still wants to give his away.
ayrton252001@yahoo.com
Old Apr 29, 2003 | 11:44 PM
Edward's Avatar
Aww free endlinks? If anybody's gettin' free endlinks, it's got to be me. It's my thread If Don brings his down to FFW Houston, I'd be more than happy to buy him Bob, if you dig up the parts list could you email it to edward98athotmaildotcom? Just change the at to @ and dot to .
Thanks,
Edward
Old Apr 29, 2003 | 11:50 PM
RTKILLA's Avatar
Just cut and weld your stock ones, thats what I did and they are fine.
Old Apr 30, 2003 | 01:22 AM
Tim Skelton's Avatar
I have the So-Cal links. Nice pieces.
I don't have them on right now because I took them off for rattle diagnosis (no rattle found) and have not yet put them back on.
But I also have drilled several holes in the frame for various mounting options. This works nearly as well, but the adjustable links let you find the right swaybar angle before you drill.
I will probably put mine back on one day, but need to add some spacers under the swaybar mounts first to provide some extra clearance for the diff cover:
Note the So-Cals are in a higher hole I drilled:
Old Apr 30, 2003 | 02:15 AM
Ayrton's Avatar
Tim,
That picture reminds me of something…
How much clearance do you have between the bottom of the bed, and the pan hard bar?
Old Apr 30, 2003 | 04:10 AM
VINNIE's Avatar
Cut and welded here
Old Apr 30, 2003 | 09:52 AM
Originally posted by Ayrton
Tim,
Not enough:
Old Apr 30, 2003 | 07:06 PM
Don's Bolt's Avatar
Thanks,
Edward
I'll se what I can do, but you might owe me more than just
