need belt size.
Old Apr 25, 2003 | 04:11 AM
YAEGER's Avatar
need belt size.
does any one know the belt size or the part # .i got the 6# lower and even after breaking off the that little piece off the tensioner it still feels to tight also super gets real hot and does'nt sound to good hoping that a little bigger belt will help by taking off some off the down pressure on the snout of the super any help would be greatley app. thanks all.
Old Apr 25, 2003 | 06:42 AM
redlightspecial's Avatar
Try a Goodyear Gatorback belt. For a 6 lb lower, you need #4080685. REM has them in stock, if you have problems finding it locally.
Old Apr 25, 2003 | 06:59 AM
YAEGER's Avatar
thanks ill see if i can find on locally if not ill give them a call.
Old Apr 25, 2003 | 07:35 AM
Marc Carpenter's Avatar
4080685 is too big ....
Unless there is a very big difference in the belt idlers, or something that is not evident, the 4080685 is too large.
I have a Metco 6# lower pulley, and originally installed the 4080670 Gator Back belt on my L. I just took it off and put a 4080665 on and it fits just fine.
I believe you will find the 4080685 will give you a "lot" of slippage.
Marc
Old Apr 25, 2003 | 11:02 AM
YAEGER's Avatar
crap[ now i dont know witch on to get i deffenitly dont want slippage i have the jdm lowwer pulley i would give them a call but there the ones that said break off that piece off the bracket ever since i did that the super sounds like it hurtin anybody elese have any suggestions?
