Electric Fan Install Help
Old Apr 24, 2003 | 04:45 PM
urstruck's Avatar
Ok, i'm installing the JDM Fan kit and have everything done but the damn drain plug on the bottom.
I can't for the life of me get the 5/16 allen bolt in there to break loose. I tried with an allen wrench at first, no way that was working. Now I have the 5/16 socket and still can't move it, i'm afraid I will strip the bolt.
Any ideas.
Old Apr 24, 2003 | 05:16 PM
clonetek's Avatar
i had to use the hex socket to get the plug out a couple of days ago when i did mine...
get a long extension & get yourself some leverage.. maybe gome penetrating oil will help...
oh, and watch out for the GALLON of %!#%^!$# antifreeze that will come out after you...
Old Apr 24, 2003 | 07:24 PM
AZBLACKMONSOON's Avatar
I'm installing mine tomarrow, i read somewhere ,somebody used a shop vac hose stuck in the radiator bottle creating a vacuum when they got the plug out they didn't lose a drop of antifreze. Find out tomarrow if ti works.
Old Apr 24, 2003 | 08:52 PM
DHFerguson's Avatar
https://www.f150online.com/forums/sh...hreadid=114194
Old Apr 24, 2003 | 09:17 PM
urstruck's Avatar
Ahhh, well after trying for an hour and half to get that drain plug off to put the sensor in, I finally screwed it up enough to where it was trashed.
So after drilling a hole thru the bolt , I got the "easy off" tool in the hole. And after another hour or so screwing with that it still won't break loose, in fact I already broke one "easy off" tool trying. "Easy off" my azz.
I have run out of ideas and energy. Probably have to take it to a shop and have someone remove that damn thing. Any one else have this much trouble. Mine is a 99 so that plug has had lots of time to cement itself in place.
Old Apr 24, 2003 | 10:52 PM
tallimeca's Avatar
hmm
if you are using the correct allen head socket.....and make sure it's not worn.....there should be any trouble. You could always shot a little heat at it
