fred nitrous controller adjustment
Old Apr 23, 2003 | 04:58 PM
easterisland's Avatar
Question fred nitrous controller adjustment
Anyone use the NX fred controller for their nitrous setup?
What settings are you using?
I finally installed mine today and set it at a .8 second delay with a 20hp start going to 100hp in 5 seconds.
Is this too much or not enough?
What do you guys use as the frequency setting. It says that 14-16 is best...I set it at 16Hz.
I was also thinking about the stage two time and if I should just go to full power at a certain point instead of ramping up.
Anyone?
Old Apr 23, 2003 | 06:30 PM
Rob_02Lightning's Avatar
easterisland
Sorry not using any controller here
But then again I only used 65 HP Nitrous Jets on my last run.
Mine seems to work fine giving it all to me at once,
Got 75 HP in there now for the next time out.
I would imagine 100 HP is prob too much all at once ???
Does it launch well with that much juice HP "all at once" or does it NOT launch well and that why your getting the controller ???
Just interested in knowing incase I ever step it up to 100 HP
Old Apr 24, 2003 | 10:51 AM
I have the KB blower and the nitrous. I just can't get traction spraying the 100 shot off of the line. I can't get traction w/o spraying off the line. Sure some of the blame is the track, some is the 28x11.5x16 hoosier dots, and some is me.
I'm getting about 1.9 60 foot times with the 100 shot off the line and I have slicks, PI 2600 stall converter. I get a little better with no juice, 1.69 was my best so far.
